need wheel dimensions.
Old Oct 25, 2003 | 08:24 PM
Smokin Joe's Avatar
Smokin Joe
Default need wheel dimensions.
I'm sure if I searched long enough I would have eventually found some archived info to help...but since I don't have time for that.
I need the wheel dimensions for a vette. Like bolt pattern distance (mm), offset, etc.
I am looking at putting some 18" OZs on the front. They are 8" wide. I'll probably put the same thing on the back. Will they fit, without rubbing?
Old Oct 25, 2003 | 08:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: need wheel dimensions. (SpyRacing)
Stock wheel dimensions for a C5 are 17x8.5 front, 18x9.5 rear. I don't know the offsets of those.
The Z06 wheels are 17x9.5 front, 54mm offset and 18x10.5 rear, 58mm offset.
The bolt pattern for all C5's is 5x120.65mm (or 5x4.75")
You can certainly run an 18"wheel in the front...the width, offset and tire size will determine if you rub or not. With only an 8" wheel, I doubt that would happen.
:cheers:
Old Oct 27, 2003 | 02:11 AM
Smokin Joe's Avatar
Smokin Joe
Default Re: need wheel dimensions. (Y2Kvert4me)
Thanks for the help!
To need wheel dimensions.
