Vehicle/engine Break-in, Science or Voodoo?
Old Oct 26, 2003 | 12:11 PM
BHP's Avatar
BHP
Default Vehicle/engine Break-in, Science or Voodoo?
Need your experience on the proper way to break-in a new C5. If anyone has dyno results that would be appreciated.
Popular methods:
1. The standard break-in is using the owners manual recommendation.
2. The altenatives that some mechanics and racers use.
Lets talk about item #2.
Most agree that gears and transmissions require light load conditions for say 500 miles to properly mate gear sets.
Engine Break-in:
Engine builders say you need to run the motor somewhat hard or the rings will not seat properly.
There is this idea that you should "drive the car like it was stolen." The objective is to seat the rings in the first 500 miles then dump the oil. The recommendation is to run the engine up to 4-5k RPM range (no redline). Then heat cycle, drive the car for say 30 minutes and cool down then drive again. No crusing on the freeway. Here is an interesting link: http://mototuneusa.com/break_in_secrets.htm
Please post your experiences and findings. Thanks for you time!
[Modified by BHP, 9:11 AM 10/26/2003]
Old Oct 26, 2003 | 12:21 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Vehicle/engine Break-in, Science or Voodoo? (BHP)
Dont forget about the wheel bearings, clutch assemblies, brakes, rotors, pads and things of that nature... They need a break-in period too. :smash:
VR :cheers:
Old Oct 26, 2003 | 12:23 PM
vetterdstr's Avatar
vetterdstr
Default Re: Vehicle/engine Break-in, Science or Voodoo? (vetterdstr)
another thing to think about... Racing is not about long term wear... it is about short term (hard) usage. Its not really fair to compare racing cars to production cars IMO.
VR :cheers:
[Modified by vetterdstr, 9:24 AM 10/26/2003]
Old Oct 26, 2003 | 12:32 PM
Mike Mercury's Avatar
Mike Mercury
Let me rephrase what "they" said:
you need to run the motor somewhat hard or the rings will not seat quick enough on cars that are only used for racing.
Even if not driven hard, rings will eventually seat properely. But on a car that is only driven at the track... you want them to seat quickly. You see; for that application - the engine cannot be driven 3k miles before it's first race. So they expedite the process by runiing the engine hard under a heavy load.
Old Oct 26, 2003 | 12:59 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Vehicle/engine Break-in, Science or Voodoo? (Mike Mercury)
That may help the rings seat quicker...but what about the valvetrain and valvesprings? I would think you'd want to baby it for a while before subjecting it to high rpm's.
:cheers:
[Modified by Y2Kvert4me, 11:59 AM 10/26/2003]
Old Oct 26, 2003 | 01:17 PM
RUBYREDVET's Avatar
RUBYREDVET
Default Re: Vehicle/engine Break-in, Science or Voodoo? (Y2Kvert4me)
:iagree: Best to stick with owners manual instructions. IMHO :D
Old Oct 26, 2003 | 06:45 PM
C5inWV's Avatar
C5inWV
Just drive it.
You have a warranty, right?
:p:
Old Oct 27, 2003 | 10:25 AM
BHP's Avatar
BHP
Valve springs are not an issue. I have broken-in many flat tappet cams with no valve train damage.
Old Oct 27, 2003 | 10:42 AM
TheBigGuy's Avatar
TheBigGuy
99 mm6 coupe 57,000 miles. Followed the Owners Manual for the break in schedule. NO engine problems, burns 1 Qt Mobil 1 10 - 30 in 3,000 miles. Runs like a raped ape. No other problems related to the drive line. I guess you could call me a " believer " of following the advise of the builder. My 2 CTS. :cheers: :seeya :chevy :flag
To Vehicle/engine Break-in, Science or Voodoo?
