Streetable compression question!
Old Oct 27, 2003 | 03:56 PM
Mike TexaSS's Avatar
Mike TexaSS
Default Streetable compression question!
As most of you know my 382 Stroker broke a timing chain last week. We got the heads off today and got them to my head porter. Outta 16 valves all but 4 were bent. Im gonna have some cool paper weights for my desk.
My engine builder did the math and we found out the compression is right at 12.78 to 1 mighty high for pump gas and texas heat. I need to lower the compression. We are looking at some Cometic gaskets with a .60 crush size. Which should bring the comp ratio to 12.2 to 1. Is this streetable?
Old Oct 27, 2003 | 04:18 PM
kumar75150's Avatar
kumar75150
Default Re: Streetable compression question! (Mike TexaSS)
no 11:1 is good. 11.5:1 max.
Get another set of heads.
Old Oct 27, 2003 | 04:25 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Streetable compression question! (kumar75150)
I wouldnt go past 11.0 - 11.2 if you want to run on 92 octane. Of course, if you choose a cam properly and run 94 octane you can get away with more compression.
My 436 is 11.0 and it runs great on 94... I had it at about 12.0 last year and it would detonate to death on 94, especially in the summer.. We went from flat top pistons to dish pistons to lower the CR and it works great now at the 11.0.
Old Oct 27, 2003 | 04:31 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
My new stroker will have 11.15cr and I could have taken it to 11.5 tops on 93, I also had ARE put a Cloyes la racing timing set in (about $400) so as not to chance the changing of the valves--as long as you have the heads off can't your heads guy shroud a little or even flycut the pistons as long as you are having all new valves I would think a bit out of the combustion chambers would solve your problem they are probably going to have to put new valve seats as well anyway--
Old Oct 27, 2003 | 04:34 PM
Phil97SVT's Avatar
Phil97SVT
My car is setup with 12.3:1 and no issues of detonation or knock.
Phillip
Old Oct 27, 2003 | 04:59 PM
SFVetteman's Avatar
SFVetteman
A key factor is the overlap of the camshaft. The more overlap then the less compression pressure you will have. That is the reason Phil97SVT can run 12.3 and I cannot.
Old Oct 27, 2003 | 08:12 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Streetable compression question! (SFVetteman)
:iagree: This is a very good point.
Old Oct 28, 2003 | 04:43 PM
SpinMonster's Avatar
SpinMonster
I wasn't even gonna bother until I saw that somebody knew something about the effects of static and dynamic compression dependance on cam overlap. Many of the tuners have told me about cars (even in CA) running up to 12.2:1. So the answer is if you get no knock with your present set-up then the CR is fine.
To Streetable compression question!
