Part #'s needed
Old Oct 27, 2003 | 04:32 PM
2KVetteMan's Avatar
2KVetteMan
Default Part #'s needed
Guys I had a friend install a cam for me on my vette a Lunati cam :D . It was running great unitl my serpintine belt got chewed up.
Bought a new serpintine belt part # 12572188 at the dealer $59.99 :smash: .
Put the new one on and it started to slide off as the engine was running. Notice my crank pulley was not aligned. I stuck my hand down by the crank bolt and could turn it by hand :cuss .
So I took it all apart myself on Sunday with JMX website "JMX you are the man."
So this is where I have questions.
1) The belt part number for the AC smaller belt.
2) The crank pulley bolt part number.
3) I notice there was oil coming from behind the crank seal, most likely the seal broke is there a part number for that as well.
4) What about the timing cover? Is there a gasket for that.
I only got to remove the steering rack last night and next will be the timing cover and then the crank pulley. Any help would be great. Also its not hard just time consuming and its been fun learning this. :cheers:
Old Oct 27, 2003 | 05:19 PM
SFVetteman's Avatar
SFVetteman
Default Re: Part #'s needed (2KVetteMan)
1) A/C Compressor belt: 12559326
2) Crank Pulley bolt: 12557840
3) Crankshaft seal: 12561244
4) Timing cover gasket: 12558013
Those should be the correct numbers for a 2000 :cheers:
Old Oct 27, 2003 | 05:30 PM
2KVetteMan's Avatar
2KVetteMan
Default Re: Part #'s needed (SFVetteman)
Sweet thank you :cheers: :cool:
To Part #'s needed
