Fix for Rocking Seat
Old Oct 27, 2003 | 08:24 PM
kenrobb's Avatar
kenrobb
Default Fix for Rocking Seat
Had the chance to work on a 97 power driver set that had the 'rocking" problem. This link goes to web page showing write-up of what we did to fix the rocking. http://js-x.com/robbs/ken/corvette/seat/ Owner says rocking is no longer there. I would be interested to hear if anyone else has taken a seat track apart and if it had the "slack" space in the assembly.
Old Oct 27, 2003 | 08:50 PM
Admiral Fairway's Avatar
Admiral Fairway
Default Re: Fix for Rocking Seat (kenrobb)
Great write up, looks like a good winter project.
Old Oct 27, 2003 | 09:21 PM
alanh's Avatar
alanh
I didn't wait for your pictures to open, but from the write-up, I think you have a solution to the problem. I've had mine apart and there is a rubber type spacer washer on both sides of the nut that runs on the worm gear, and takes up the slack you referr to inside the silver housing. I suspect that the rubber spacer washers are being crushed and cut when the seat is run to the extreme back position in the easy exit mode. Once they are crushed and cut, they eventually fall out and leave the slack in this part that causes the rocking seat. The solution is just as you have done, put something in there to take up the slack and won't be crushed, as long as it doesn't cause a bind in the works.
Old Oct 27, 2003 | 10:22 PM
kenrobb's Avatar
kenrobb
Default Re: Fix for Rocking Seat (alanh)
We didn't find anything under the seat when it was removed. I suspect what ever was in there, fell out, and had been cleaned out by previous owner. Would like to see what is in a new solid seat.
Old Oct 27, 2003 | 11:08 PM
bowtiebandit's Avatar
bowtiebandit
I just threw out 2 last week..I'll try and get you a pick of the next one I do.
Old Oct 28, 2003 | 10:57 AM
saber's Avatar
saber
KENROBB
Very interested is yor fix but the pics won't come up.
Old Oct 28, 2003 | 11:06 AM
kenrobb's Avatar
kenrobb
Default Re: Fix for Rocking Seat (saber)
Came up for me now; server may be slow. I have cable; dial-up's may be slow!
Old Oct 28, 2003 | 01:17 PM
BayouVette's Avatar
BayouVette
Looks like we got a winner.. :thumbs:
Old Oct 28, 2003 | 01:22 PM
Thunder7's Avatar
Thunder7
Bookmarked for future reference. :thumbs:
Old Oct 28, 2003 | 02:25 PM
DSTJ99's Avatar
DSTJ99
Default Re: Fix for Rocking Seat (Thunder7)
Awesome write up and find. I have not taken the seat bottom apart but I want to fix the problem and this is the answer. Seems it will take some work, but no costs that I can see besides a few washers. :thumbs:
Old Oct 28, 2003 | 02:51 PM
BHP's Avatar
BHP
Fax this write-up to GM enginnering with a bill!
Old Oct 28, 2003 | 08:14 PM
Admiral Fairway
You should put this in the tech tips section.
Old Oct 28, 2003 | 08:41 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
This a gret write up. I don't have the "rocking seat" problem as of yet but, I am sure it will show up sooner or later. Just like my leaking diff and cracked window molding. I am awaiting the arrival of Column Lock issue and this. I have saved for future reference. Thanks
To Fix for Rocking Seat
