PCM CODE10 ACTIVE HANDELINE SUSPENSION
Old Oct 28, 2003 | 09:55 AM
JAMUSA's Avatar
JAMUSA
Default PCM CODE10 ACTIVE HANDELINE SUSPENSION
MY O3 ZO6 HAS THE FOLL WING MOD:ATI PROCHARGER,CAM ,HEAD,BIG VALVE PKG,L/T HEADERS,NO CATS,H-PIPE,CAT BACK SYSTEM,3:73 GEAR.MAKES 575.8RWHP/540FT.LB TQ.@5PSI BOOST.THE DRIVABILITY IS GREAT.TOOK THE CAR OUT FOR A SPIN THIS WEEKEND N RUNNING ABOUT 175MPH..WHEN SUDDENLY I RECEIVED A "ENGINE"CHECK LIGHT.THE CAR I ASSUMED WENT IN THE "LIMP MODE"AND WOULD NOT GO OVER 5-7 MPH.THE MESSAGE CENTER READS-PCM CODE 10 ACTIVE HANDELING SUSPENSION.I CLEARED THE CODE AND THE CAR SEEMS TO PERFORM AS BEFORE.I HAVE CHECKED WITH SEVSRAL DEALERS,N NO ONE HAS A CLUE AS TO WHAT A CODE 10 IS.ONE PERSON SAID THAT IT WAS A CHASSIS CODE,ANOTHER SAID CODE COMES IN ABC N THIS WAS A "C"CODE,ANOTHER SAID THIS HAPPENED BECAUSE I WAS NAT IN COMPETETION MODE N HAVE EXCEEDED THE PARAMETER OF THE PERFORMANCE.ALL THESE ARE SPECULATIONS.HAS ANYONE EXPERIENCE ANY CODE SUCH AS THIS?
Old Oct 28, 2003 | 10:43 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: PCM CODE10 ACTIVE HANDELINE SUSPENSION (JAMUSA)
This code can come about in a few diff ways, Steering wheel not centered, wheel speed variation, Brake lines not grounded.... best thing to do is to take it to the dealership and let them fix it. Your mods have nothing to do with this code and they should fix it under warranty. :smash:
VR :cheers:
Old Oct 29, 2003 | 08:38 AM
JAMUSA's Avatar
JAMUSA
Default Re: PCM CODE10 ACTIVE HANDELINE SUSPENSION (vetterdstr)
i checked the car over everything seems to b in order,but i have not yet driven the car......road is wet.
To PCM CODE10 ACTIVE HANDELINE SUSPENSION
