Service ABS, Active Handling, TCS (have code), Code TCS C1214 - Problem is intermittent
Old Oct 31, 2003 | 03:00 AM
JohnnyNarcosis's Avatar
JohnnyNarcosis
Default Re: Service ABS, Active Handling, TCS (RskyBns)
This may sound nuts but I had similar codes come up on the DIC recently and the reason was the wheel speed sensor connector on the front passenger side hub. It turns out that each of those modules depends on the wheel speed sensor data coming in from each hub. I removed each wheel and cleaned the connector halves with compressed air. Problem solved for my situation.
Thought it might help to mention it.
Good luck.
Old Oct 31, 2003 | 04:07 PM
RskyBns's Avatar
RskyBns
Default Re: Service ABS, Active Handling, TCS (JohnnyNarcosis)
Yep....I told you it would be "just my luck". Three days in a row it is happening...the 4th day I take it to the dealer it doesnt happen and everything checks out....today (day 5) it has been happening for the last few hours :banghead: WTF is going on? What's the next step? :banghead: :skep: :boxing :banghead:
[Modified by RskyBns, 1:41 PM 10/31/2003]
Old Nov 3, 2003 | 12:35 PM
RskyBns's Avatar
RskyBns
Default Re: Service ABS, Active Handling, TCS (have code), Code TCS C1214 -
Well.....of course, without fail,...the messages and codes were going off all weekend. Brought it back into the dealer first thing this AM. I think the service rep is getting annoyed with me :boxing ....I just want the thing fixed. No reason why I should be driving around in the rain without any ABS, TCS, or AH. Sooooooo....I'll keep ya updated on what happens this time.
By the way....when I took it in...the "Service AH, TCS, ABS" messages were going off and the service rep saw them first hand.....he didn't seem too interested though. :rolleyes: ARGhhh.....ok, I'll keep ya posted.
Old Nov 3, 2003 | 10:03 PM
RskyBns's Avatar
RskyBns
Default Re: Service ABS, Active Handling, TCS (have code), Code TCS C1214 - (RskyBns)
Well...the car was at the dealer since 8am this morning. And FINALLY I get a call at 4:30 in the evening....."Well, seems like that solenoid you were talking about is toast." I'm like....no $h!t moron!.....anyways....even though they ran a full day of diagnostics last week and then again today....he says the tech still needs to do some more diagnostics tomorrow morning before they file the GMPP claim. I talked to the parts dept. there as well....it will take them at least a day to get the part....told the service rep this and he said he can't do anything about getting the part until they finish tomorrows diagnostics.....seems totally dumb to me. That means that probably it will just have to sit there most of the day and same on the day after until they get the part in. They will have had the car for 4 days in order to do a 2 hour job. :rolleyes: :banghead:
[Modified by RskyBns, 7:04 PM 11/3/2003]
Old Nov 3, 2003 | 10:21 PM
bowtiebandit's Avatar
bowtiebandit
Sorry for your frustration...I'm sure the tech at this point just doesnt want to make any mistakes. Keep us posted
Old Nov 4, 2003 | 01:53 PM
RskyBns's Avatar
RskyBns
Default Re: Service ABS, Active Handling, TCS (bowtiebandit)
Bowtie...thanks for your insight in this matter.
The service rep just called and said that the part would be in tomorrow morning and I should be able to get the car by noon. That will be 4 days of service. Anyways....I asked him if it was the EBCM or the EBCM and the BPMV. He said it was just the BPMV/ABS Unit that needed to be replaced. Does that make sense? From what I read in the service manual I wouldn't think that would be the case. Thoughts? :confused:
Old Nov 4, 2003 | 02:49 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
When my EBCM went bad and started the throw the same code as yours, the abs worked each time I ran the car cold, but after it warmed up it quit working. Based upon that it was likely to be an electronic part. This was confirmed when we replaced only the EBCM and it has worked great ever since. Good luck, at least yours is under warranty. :hurray:
Old Nov 4, 2003 | 02:57 PM
H82BFST's Avatar
H82BFST
Default Re: Service ABS, Active Handling, TCS (Rippied Z06)
I may be replacing the EBTCM soon also, anyone know what the part costs and the best place to get it?
Old Nov 4, 2003 | 03:01 PM
Jason98's Avatar
Jason98
For what its worth..I have a 98 I bought new and got the same error codes, but only when I go over 75-80mph. Doesn't happen every time, maybe 60%. Of course when the car was under warranty the dealer could not find anything wrong. I guess I will put up with it unless it gets worse.
Old Nov 4, 2003 | 03:02 PM
Lawdogg's Avatar
Lawdogg
Default Re: Service ABS, Active Handling, TCS (H82BFST)
GM Parts direct sells it for under $500, but their shipping is based on price so it will cost about $150 for shipping. If you can get it from a dealer for a jobber price, it should be around $600. Retail is about $950. :eek:
Old Nov 4, 2003 | 03:18 PM
H82BFST's Avatar
H82BFST
Man, that is still one expensive piece. Will get one through work for best price. :)
Old Nov 5, 2003 | 11:48 PM
RskyBns's Avatar
RskyBns
Okay everyone....just picked the car up. Here's the skinny of what was done from my paperwork....
Correction: Replace ABS Module - Part # 12216561
Part # 12216561 is the EBCM and it cost $935.72 just for the part. :eek:
$200 for the deductible....Warranty has paid for itself now. :reddevil
Still took them 4 full days to take care of this though :rolleyes:
I'm just glad it's done....now I can do my big brake job with peace of mind tomorrow :auto:
Old Nov 6, 2003 | 08:13 AM
  #33
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default Re: Service ABS, Active Handling, TCS (Jason98)
If you had the problem documented on the repair order during warranty.......take it back now!
Ours just went in the shop for the 3rd DS rear axle seal, 2nd belt noise and 1st front PS wheel bearing assy. All documented under the warranty that ran out in March but "dealer could not find" wheel bearing issue.
This will be covered under a, "Pre-exisitng condition", the other 2..........never fixed correctly the 1st time :cheers:
