Wanted feedback on your Yank SS3600
Old Oct 28, 2003 | 07:01 PM
IMQUIK's Avatar
IMQUIK
Default Wanted feedback on your Yank SS3600
I have 3.73's ready to go in & need a TC ASAP!!
How does it drive on the highway?
How is it out of the hole?
My car is stock. I have LS1 Edit,see sig for all other mods.
Old Oct 28, 2003 | 07:14 PM
Mitch C's Avatar
Mitch C
Default Re: Wanted feedback on your Yank SS3600 (IMQUIK)
I had the ST3500 which is nearly identical to the SS3600 in permformance and street manners. I also had 3.73 gears, your highway driving will be just like your stock converter once the SS3600 locks up. With 3.73 gears and a SS3600 you will need DRs to get consistent traction out of the hole. :cheers:
[Modified by Mitch C, 6:16 PM 10/28/2003]
Old Oct 28, 2003 | 07:40 PM
brialex42's Avatar
brialex42
Default Re: Wanted feedback on your Yank SS3600 (Mitch C)
:iagree: I have the SS3600 with 3.42's. Traction is a huge problem on street tires. However, when you can get it to hook .. Hold ON!
As for daily manners.. like it was mentioned above, once the TC locks up at speed it is fine. Off the line in daily driving is somewhat of a pain with the 3.42's but with your 3.73's this should help that situation.
Old Oct 28, 2003 | 08:28 PM
Killrwheels's Avatar
Killrwheels
Default Re: Wanted feedback on your Yank SS3600 (brialex42)
Ive got a SY-3500 for 750.00 ... new in box. If you overnight money order tomorrow, you could probably have it in Georgia early next week.
Old Oct 28, 2003 | 09:27 PM
IMQUIK's Avatar
IMQUIK
Default Re: Wanted feedback on your Yank SS3600 (Killrwheels)
I want an SS or ST :yesnod: SY's STR is low. Thanx anyway :cheers:
[Modified by IMQUIK, 9:28 PM 10/28/2003]
Old Oct 28, 2003 | 10:10 PM
Killrwheels
no problem, worth the contact. With the higher STR are you loosing some power up top (above rated stall) versus at the beginning ?? http://www.converter.cc/technical_discussion.htm
Old Oct 28, 2003 | 10:46 PM
2001 Red Coupe Bandit's Avatar
I have it tight on the street. I run BFG Drag Radials ALL THE TIME!
1.65 60' is my best
Old Oct 29, 2003 | 11:24 AM
cscollis's Avatar
cscollis
I just switched from a 3000 stall to 3800 with 2.55 str and it rocks about the same for looseness. With 3.73 it would feel tight as Gary's pucker at the Tree! Get a SS 3600 or 3800 you wont be disapointed!
Old Oct 29, 2003 | 11:39 AM
OBSSSD's Avatar
OBSSSD
Default Re: Wanted feedback on your Yank SS3600 (cscollis)
With that much gear you need a PT4000 2.3 STR. SS converter will feel like a stock TC with 3.73's
Old Nov 3, 2003 | 09:34 PM
IMQUIK's Avatar
IMQUIK
Default Re: Wanted feedback on your Yank SS3600 (OBSSSD@work)
Next!
To Wanted feedback on your Yank SS3600
