Power window adjustment question..
Old Oct 29, 2003 | 02:28 PM
LPDesRoche's Avatar
LPDesRoche
Default Power window adjustment question..
Before I purchased my 98 Coupe the previous owner had the passenger side power window motor replaced by the dealer. Ever since then the passenger side window does not go up as far as the drivers side window. This allows air in at high speeds and sometimes water if parked outside during a hard rain. I kow you can adjust the "TIP IN" or angle of the window with the little reverse torx head screws but how can you adjust the final height of the window?? It's touching the weather stripping of the top just not going all the way into the little groove like the drivers side does. Any suggestions????
Old Oct 29, 2003 | 04:59 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Power window adjustment question.. (LPDesRoche)
The glass is attached to the regulator with 2 clamps,The clamps are slotted so you can loosen the attachment bolts and you can move the glass up or down for proper fit.There are also adjustment stops,but simply repositioning the glass on the regulator is an easier task :yesnod:
Old Oct 29, 2003 | 05:07 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Power window adjustment question.. (C-5 TECH)
Thanks, I will give that a shot.....The wind noise drives me crazy....
-Lee
To Power window adjustment question..
