Uneven pavement causing "swaying"
Old Oct 30, 2003 | 11:23 PM
dads01dream's Avatar
dads01dream
Default Uneven pavement causing "swaying"
Hey All,
My '01 has been sort of swaying a bit over uneven pavementlately, any suggestions how to eliminate this? Could I have some suspension bolts backing out on me? I'm still running the factory runflats (~12K miles).
I have the adjustable suspension (F45?), any suggestions what to look at would be most appreciated.
:seeya
Old Oct 31, 2003 | 05:49 AM
AMGPilot's Avatar
AMGPilot
Default Re: Uneven pavement causing "swaying" (dads01dream)
Hello dads01dream,
I have a 2004 Coupe with the F55 adjustable suspension and I upgraded to the Z06 sway bars because the stock sway bars on my car were sooooo small! It made a huge difference in the handling of the car without sacrificing the ride comfort.
Here are a few pics of my mod so you can see the bigg difference in the size of the stock and Z06 sway bars.
FRONT SWAY BAR INSTALL
REAR SWAY BAR INSTALL
[Modified by Yellow2K4, 6:08 AM 10/31/2003]
Old Oct 31, 2003 | 08:13 AM
staggarlee's Avatar
staggarlee
I have an 01 with 19k and runflats. Mine sways side to side when hitting uneven pavement also. I just got the car last week and noticed that right away. It's not out of alignment but it'll pull to one side pretty hard when changing lanes on an uneven highway.
I don't have the adjustable suspension or the ride control I think it's called.
[Modified by staggarlee, 1:14 PM 10/31/2003]
Old Oct 31, 2003 | 08:38 AM
dads01dream
Default Re: Uneven pavement causing "swaying" (Yellow2K4)
Yellow2K4 - Man, those are some BEEFY sway bars for sure!! I thought the rear bars were all the same as the Z06 from the factory from 2001 on? Clearly from your pix I'm mistaken, but I thought GMpartsdirect told me not the get the rear bar as my car is an '01.
Did you have the same "swaying" problem I mentioned in my original post? I wouldn't think the sway bars would have eliminated that situation. Lemme know, please.
Staggerlee - I am experiencing EXACTLY what you're talkin' about. Do you think this is just normal for the car due to the hard rubber and wide tire profile? Or could something else be amiss :skep: ? This situation is really starting the dampen my enjoyment of the car.
Anyone else have some insights into this condition?
:seeya
Old Oct 31, 2003 | 08:45 AM
jackmott's Avatar
jackmott
these sorts of issues sound like shock dampening issues.
might try some 04 z06 shocks, or some aftermarket ones.
Old Oct 31, 2003 | 08:47 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Part of the issue may be associated with the runcraps. Cannot state that for sure as I also changed my sway- bars at the same time I went to non- runcraps.
However, with the above changes there was an significant change for the better in the problem you note.
Also note that my sway- bars are after market, not GM. They are significantly stronger, and weight much more, than GM's. Also, I changed the end links, and that contributes to the 'better' handleing than the OEM.
Old Oct 31, 2003 | 09:26 AM
User 81424's Avatar
User 81424
I have many laps of the Nurburgring in my 02 Z06 and I have driven a C5 with the F45 suspension around the ring too (and will again over Thanksgiving!!!!!! :). He had Hotchkiss (sp?) anti-sway bars, poly bushings, and sticky tires and I really couldn't tell a difference between his and my car, and I was following this guy, a much better driver who was in my Z06; so I was driving very fast and hard. Start with at least the Z06 bars and then go to better tires when the run flats wear out and you should be happy.
Old Oct 31, 2003 | 10:30 AM
MarginalTraction's Avatar
MarginalTraction
My '02 coupe with F45 was improved by an alignment. The car wasn't tracking properly and I had them reduce the negative camber (more towards zero camber).
Old Oct 31, 2003 | 10:36 AM
rwlc5's Avatar
rwlc5
Default Re: Uneven pavement causing "swaying" (MarginalTraction)
I think the main problem is the GY runflats. I changed to the Michelin Pilot Sport runflats and there is a world of difference. Softer ride, less noise and the car doesn't track to the left or right when it hits the little ruts in the road.
Old Oct 31, 2003 | 10:53 AM
Mehfoud's Avatar
Mehfoud
Default Re: Uneven pavement causing "swaying" (rwlc5)
I have the Z51 on my FRC and encounter the problem everyday when driving to work. It is not a sway bar issue, but just the stiff suspension and stock shocks riding on the Bad Year Run Craps (run flats).
would change tires and shocks and the swaying is annoying.
Old Oct 31, 2003 | 11:20 AM
speedjohnson's Avatar
speedjohnson
Default Re: Uneven pavement causing "swaying" (Mehfoud)
It's not the tire make, it's the tire width and alignment.
The wide tires will always give you trouble when tracking in "ruts" and on uneven pavement. There's no way to totally get around it. The types of things that you can do to minimize the "wandering" will generally be detrimental to handling and tire wear.
Probebly the best way to go is to first check the alignment. While excessive negative camber and near zero toe will promote the tendency to "wander in the ruts", these features also promote good cornering...so changing these too far from stock might not be what you're after in a sports car. But, you can help your situation by increasing the caster to the max stock setting with only minor effects on handling (it will be less eager to turn in on cornering) and give you only a little extra tire wear. The increased caster angle will help the car track straighter.
If it still wanders, and you don't care about cornering, then start dialing out negative camber and start increasing toe in. If it still isn't good enough, then go to real narrow tires...now I'm just getting sick...it's all a compromise.
Good luck. sj
Old Oct 31, 2003 | 11:45 AM
Kenny94945's Avatar
Kenny94945
12K mileage.
So I assume we have a wear & tear issue as opposed to a road surface change or other.
1 - Wheel Balance time
2 - Run Crap worn
3 - Tighten suspension front and rear. X member, a-arm mount bolts, sway bar mounting bolts.
4 - Look for a leaky shock.
If you find it let us know.
Old Oct 31, 2003 | 12:15 PM
LPDesRoche's Avatar
LPDesRoche
The problem is the run flats, plain and simple. I can't give you the scientific explanation for this, but I do know I had the exact same problem on not too worn runflats. Once I changed the tires the car rides totally different. It's also alot quieter, the runflats make alot of road noise. :cheers:
Old Oct 31, 2003 | 12:31 PM
HalfMoon's Avatar
HalfMoon
Default Re: Uneven pavement causing "swaying" (speedjohnson)
Good luck. sj
:iagree:
My Old Camaro SS had this problem with 275/40/17s setup with a hot alignment. Zero toe, Maximum equal negative camber. I get this on my 04, but i'm used to it.
speedjohnson
Default Re: Uneven pavement causing "swaying" (LPDesRoche)
For the sake of debate, there may be a lot of reasons to change from runflats to Pilots. I have stock runflats on my '97 and Michelin Pilots on my '02. The Pilots are stickier, less noisy and wear out a little faster than the Goodyears.
However, let's not have this guy spend 1,400.00 on new tires that may not cure his tracking problems. He should have his basic alignment checked first.
Try this: Fronts 29# cold; Rears 33# cold. Front neg .5 degrees camber, 7 degrees caster and minus 1/16th toe in. Rear: .25 negative camber, minus 1/8th inch toe in.
This is a good first step and will only cost him 70.00.
Old Oct 31, 2003 | 02:28 PM
Monster231's Avatar
Monster231
Default Re: Uneven pavement causing "swaying" (CPT Z06)
Anytime you run tires as wide as our, they will have a tendency to follow the grooves in the road, for the most part it has nothign to do with suspension or tires.
Old Oct 31, 2003 | 02:47 PM
LPDesRoche's Avatar
LPDesRoche
It's worth a check by all means, but I changed nothing but my tires and problem went completely away. So take that for what it's worth. :cheers:
-Lee
To Uneven pavement causing "swaying"
Old Oct 31, 2003 | 02:52 PM
dads01dream
Hey Mr. Speed.....
Thanks for lookin' out for my wallet!! I will give your suggestions a try first, then move on the tires. Heck, I've been itching to get out of the runcraps for some time now.
Keep up the great suggestions everyone, I really appreciate all of your input.
:cheers:
Old Oct 31, 2003 | 03:35 PM
Mark VerMurlen's Avatar
Mark VerMurlen
Default Re: Uneven pavement causing "swaying" (Monster231)
:iagree: I have upgraded my anti-sway bars to Z06 bars and have replaced my GY runflats with Bridgestone Potenzas and I still have this tendency for the car to follow ruts or groves in the road. I think you'll need to learn to live with this. It doesn't really bother me, I just need to keep hold of the wheel on roads that cause this problem. I wouldn't spend money to replace tires or suspension unless you are doing if for different reasons (I did it for performance reasons). I think you'll find you'll still have this problem after spending all that money.
- Mark
Old Oct 31, 2003 | 03:43 PM
Face's Avatar
Face
:iagree:
My Vette and Regal both do this, and the Regal doesn't have runflats. It's just a matter of wide tires on a crappy road causes this.
