Lowering Kit
Old Nov 1, 2003 | 10:25 PM
vectorz's Avatar
vectorz
Default Lowering Kit
I was interested in lower the rear end of my c5. I saw this thread:
http://www.c5forum.com/diy/lowering.php
However, it seems like it instructs to cut the springs. I'm not so sure I want to do that..
but I saw some 'lowering kits' for sale through the vendors here.. how do these work? Any cutting involved still?
Old Nov 1, 2003 | 10:36 PM
joeflyer's Avatar
joeflyer
Default Re: Lowering Kit (vectorz)
The lowering kit is a pair of longer bolts and nuts. To lower the back of the car, the nuts on the spring bolts are backed out. With stock bolts, can't go as far as the kit bolts. Can also cut the bushings.
Old Nov 1, 2003 | 10:46 PM
vectorz's Avatar
vectorz
Default Re: Lowering Kit (joeflyer)
Will cutting the bushings cause any harm to the shocks? Or will it cause drastically harsher ride?
Old Nov 1, 2003 | 11:29 PM
kh24's Avatar
kh24
Dont buy a kit from a vendor...just go to home depot and buy the bolts and nuts you need for about $4 instead of $40. Works just the same and you wont have to cut anything. Make sure you get your car aligned after about 50-100 miles.
Old Nov 2, 2003 | 02:45 AM
Ooomph's Avatar
Ooomph
It's actually the bushings being cut not the springs.
Old Nov 2, 2003 | 10:09 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Default Re: Lowering Kit (Ooomph)
:lurk:
Old Nov 3, 2003 | 04:21 PM
FKING1's Avatar
FKING1
Default Re: Lowering Kit (DocSandy)
Do not cut the rear rubber bushings. As previous thread notes, get 14mm (original size)or 9/16 bolts 2 or 3 inches longer than the stock ones, make sure the bolts are grade 8. Or you can buy just the bolts and nuts from Eckler's for $20.Very easy to install.
Fred K.
Old Nov 4, 2003 | 12:45 PM
vectorz's Avatar
vectorz
Default Re: Lowering Kit (FKING1)
Fred K.
Cool thanks for the tips! Do you know if there is a DIY picture post? And do you guys recommend installing a bump and steer kit when lowering?
Old Nov 4, 2003 | 05:16 PM
jawski's Avatar
jawski
Use 1/2", 9/16", or 13mm diameter grade 8 bolts with locking thread-type nuts (do not use nyloks, plastic will deterioate) 6-1/2" long...6" too short...7" too long! Stock bolt is 5-1/2" to end of threads (6" overall)..6-1/2" will give you plenty of bolt to play with. :yesnod:
Old Nov 4, 2003 | 05:33 PM
FKING1's Avatar
FKING1
Default Re: Lowering Kit (jawski)
I stand corrected, above post is right. Sorry. Just measured my old rear adjusting bolts. They are .497" x 6",which is approx. 12.6mm. So 1/2" or 13mm bolts are the proper size.
Fred K.
Old Nov 4, 2003 | 05:58 PM
GmPartsDirect.com's Avatar
0GmPartsDirect.com
Former Vendor
Vectorz
Please remember, some people recommend cutting the front adjuster ride height bushings located on the front spring ends. If you cut the height adjusters they can not be ordered separately, GM only sells them with the spring.
Old Nov 8, 2003 | 02:22 AM
vectorz's Avatar
vectorz
Default Re: Lowering Kit (GmPartsDirect.com)
I 'backed out' on the rear bolts as far as I can on the factory bolts and it does not look lowered at all! Are you sure I'm not supposed to TIGHTEN them as far as I can? This is the bolt I'm referring to:
http://benelliwang.badassride.com/Su...mages/rear.jpg
As you can see in the pic, the arm and the leafspring are head together by that bolt. Well I backed it out to the point where there's nothing left to back out. The car doesn't look lowered even a little!
[Modified by vectorz, 8:05 AM 11/8/2003]
Old Nov 8, 2003 | 12:41 PM
FKING1's Avatar
FKING1
Back off the nut until there are about 2 threads left is the correct way. Drive the car about 50 miles then check the height. You should have measured before lowering. The stock bolts gave me 1" on my 00 Coupe. From rr fender opening wheel arch to ground is 27" on mine which is lowered 1-7/8".
Fred K.
Old Nov 8, 2003 | 08:15 PM
WRK CAR's Avatar
WRK CAR
:iagree:
Old Nov 9, 2003 | 10:53 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
My opinion is if you lower it to much the suspension doesn't work properly. Especially with stock shocks. Keep the same rake in the car for high speed handling.
Old Nov 9, 2003 | 11:00 AM
TrplBlk01's Avatar
TrplBlk01
Lowering should take anywhere between 30-90 minutes.
Depending on tools available and experiance...
Very easy to do. Dont waste your money on lowering kits....
Old Nov 9, 2003 | 11:09 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Vectorz
This is true, however if you cut the front bushings, you can still adjust the car to stock or very near-stock height. Since the factory bolt setting is in the middle of the adjustment range, with full bushings, there is enough adjustment to raise the car 1" or so over the factory height. (No sane person would ever do this, but the adjustment range is there).
So when the bushings are cut, you can still adjust the bolts down more than they were originally set in the spring to restore the stock height of the car if need be.
:cheers:
To Lowering Kit
Old Nov 9, 2003 | 05:15 PM
SQEZN BI's Avatar
SQEZN BI
I backed off leaving 2 threads and then after driving 1 day deceided to cut the bushings. I read many posts on cutting bushings and couldnt see any problems that could arise from doing so. Got my desired ride height, no problems. The only consern with lowering is getting correct bolts if you change them ,and shock travel which all depends on how low you go by bolts or cutting bushings. :D
Old Nov 9, 2003 | 05:38 PM
FKING1's Avatar
FKING1
Default Re: Lowering Kit (SQEZN BI)
For what it is worth, this is what I did on my 00 Coupe 10 months ago. On the rear, bought 2 bolts from Eckler's for $20 and lowered 1-7/8"Did not cut bushings. On the front, cut 2/3 off the rubber bushings and lowered 1-3/4". Went up and down several times in 1/4" increments until I got the least scraping (only air dam once in a while), and the best ride quality. I am very satisfied with the results.
Fred K.
Old Nov 9, 2003 | 06:27 PM
Old Rotor Head's Avatar
Old Rotor Head
Vectorz
:eek: Oouch. Didn't cut mine and now glad of it.
