P0171 CODE ( Fuel Trim System Lean Bank 1-B) Help!!!!!!
Old Nov 2, 2003 | 02:35 PM
TNTC5's Avatar
TNTC5
Default P0171 CODE ( Fuel Trim System Lean Bank 1-B) Help!!!!!!
Anybody out there have this code before? (P0171) Fuel Trim System Lean Bank 1-B). What should i chek first? Injectors, spark plugs, MAF, vacuum? I know i am running on seven cylinders. Please chime in if you come across this code. Thanks :confused:
[Modified by TNTC5, 1:36 PM 11/2/2003]
Old Nov 2, 2003 | 03:10 PM
SFVetteman's Avatar
SFVetteman
Default Re: P0171 CODE ( Fuel Trim System Lean Bank 1-B) Help!!!!!! (TNTC5)
If you are not getting the P0174 code then you can rule out a vacuum leak, as it would cause both banks to run lean. Likewise as far as trouble with the MAF.
A scan tool would be the best way to track down the problem but without one your best bet is to pull the plugs on the driver side. The plugs should have a light tan/grey color but if you have a bad injector that is flowing too little fuel then the plug should be whiter in color.
You might want to pull a passenger side plug for comparison if you have no bank 2 codes to have the best idea of what the plugs should look like.
Old Nov 2, 2003 | 04:32 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Do you also have a P0300 code :confused:
If you are misifring on 1 cylinder that will cause the o2 sensors on that bank to read rich.
Old Nov 2, 2003 | 06:48 PM
TNTC5's Avatar
TNTC5
Default Re: P0171 CODE (runamuk)
Thanks guys, P0171 that was the only code that current and the rest were history. I haven't look at the car yet because i have to work. I am going to check it out with the Tech2 tonight and i will post to solve future problem. Thanks again.
To P0171 CODE ( Fuel Trim System Lean Bank 1-B) Help!!!!!!
