remote door locking unit
Old Nov 4, 2003 | 10:19 AM
Vince Lombardo's Avatar
Vince Lombardo
6th Gear
Default remote door locking unit
The remote control unit only works for about 5 minutes after the Fob reprograming sequence. I've replaced the battery, but it makes no difference. Has anyone had a similar problem?
Old Nov 5, 2003 | 12:39 AM
markcz's Avatar
markcz
Default Re: remote door locking unit (Vince Lombardo)
You mentioned that you did the reprogramming sequence, I would guess that means you did what the owners manual calls the 'Matching transmitter to your vehicle'. You might also have to do the 'Resynchronizing your transmitter' procedure a few pages later in the book.
If that doesn't work: Is it just one fob not working or both? If 1, probably the fob or battery. If 2, I'm out of ideas.
Good luck! :cheers:
