Looking for glove compartment code for non-HUD enabled cluster.
Old Nov 4, 2003 | 07:43 PM
ArKay99's Avatar
ArKay99
Default Looking for glove compartment code for non-HUD enabled cluster.
Does anyone know the code for a non-hud enabled cluster? The one in the glove compartment? The sticker in my car has a wear line cutting across about 8 of the codes and I can't make out about 5 of them. I know the code for a hud enabled cluster is UV6, but that is not among the legible ones. If someone could give me the code for a non-enabled display, I may be able to find that. Failing that how would I obtain the info, from the VIN? If so, do I go to GM with that? :confused: :(
Old Nov 4, 2003 | 10:59 PM
HurricaneZ's Avatar
HurricaneZ
Default Re: Looking for glove compartment code for non-HUD enabled cluster. (ArKay99)
I dont believe you will find an option code. Like if you dont have a Z06 than RPO Z06 cant be found. I hope this make sense. The only way to find out if your car has a hud enabled cluster is to pull it. I can do it in 15 minutes now. Detailed instructions with all the HUD install info you need is on my website
