Magnetci Selective Ride Control
Old Nov 5, 2003 | 07:53 AM
boomer 33's Avatar
boomer 33
Default Magnetci Selective Ride Control
dealer swears they took the protective packs out of the shocks, I turned the wheel all the way and crawled under, couldn't see the yellow strip hanging out. But Still not convinced. Are the strips really inside of the boot where you can't see them without jacking the wheel all the way off the ground? :crazy:
Old Nov 6, 2003 | 07:24 AM
boomer 33's Avatar
boomer 33
Default Re: Magnetci Selective Ride Control (boomer 33)
ttt
Old Nov 6, 2003 | 10:59 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Take the wheel off and raise the boot, if you can't see the pull tab then they are already removed.
Why do you think they are still installed, is your ride overly harsh, drive down a bumpy road and switch between tour and sport, if you can feel a difference in ride quality then the shock stuffers have been removed.
Old Nov 6, 2003 | 11:31 AM
boomer 33's Avatar
boomer 33
Default Re: Magnetci Selective Ride Control (runamuk)
I can only tell a very small difference between the two settings which was leading me to believe they , or not all , were removed. When I called and asked if they had removed them, they definitely, they remembered taking them off and throwing them at each other!! But , maybe they forgot one or two. :rolleyes:
To Magnetci Selective Ride Control
