Predator Tuner, Vararam INtake and Velocity Stack
Old Nov 5, 2003 | 01:13 PM
arbrmdangus's Avatar
arbrmdangus
Default Predator Tuner, Vararam INtake and Velocity Stack
Has anyone every used the predator to tune for the vararams leaning out at WOT any info would be greatly apprecited thanks
Old Nov 5, 2003 | 03:16 PM
AZGASSER's Avatar
AZGASSER
Default Re: Predator Tuner, Vararam INtake and Velocity Stack (arbrmdangus)
I have a blackwing and velocity stack. I used the Predator and a custom tune from James at RWTD to help with my A/F ratios. You have to look at the O2 mV values. I try to keep mine between 900 and 930 if possible. I also have LT headers and this custom tune helped with this. Also, Check you LTFT's, they should be neg. in the range of -1 to -4 any more than this and you are too rich. Dont flame me for this knowledge, this is what I have deduced over the last 5 months of searching several sites on how to use LTFT, STFT, and O2 mV reading on tuning. Your results my vary. If you have acess to a dyno with wideband O2 capability, it will be easier to tune. Good luck! :seeya
