A/C only blows on level 2 or higher!! help!
Old Nov 5, 2003 | 02:34 PM
nericreations's Avatar
nericreations
Default A/C only blows on level 2 or higher!! help!
This doesn't make any sense to me...I don't have the dual climate control, the A/C does not blow on 1, but from 2 - to it blows??? I don't get it...any sugestions? :confused:
Old Nov 5, 2003 | 02:48 PM
jimbalaya's Avatar
jimbalaya
Default Re: A/C only blows on level 2 or higher!! help! (nroberts02)
I had this same problem last week. Here is the thread:
http://forums.corvetteforum.com/zerothread?id=683150
It appears to be the blower resistor motor.
-j
Old Nov 5, 2003 | 02:59 PM
nericreations
Default Re: A/C only blows on level 2 or higher!! help! (jimbalaya)
Thanks!, does anyone know if I can change this part myself, (I'm a novice with a tool set) or should I wait till my 0 dect. warranty goes in effect and have it changed at a shop? Thanks :blueangel:
Old Nov 5, 2003 | 03:26 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The resistor is located under the right dash and retained with (3) 5.5mm screws that can be a PITA to get to...The trick is to remove the front screw and only loosen the rear 2.The resistor will then slide out.It is a DIYer if you have patience :smash: Part is about $25.00 :yesnod:
To A/C only blows on level 2 or higher!! help!
