Coolant System Question
Old Nov 5, 2003 | 10:26 PM
webdzynes's Avatar
webdzynes
Default Coolant System Question
I just discovered a pin sized hole on the top of the schroud where you put the coolant in. There appears to have been a very small amount (1/4 of an ounce) of coolant that has come out. My car has been running hot. Is it possibe a pin sized hole upsets the pressure enough to cause this problem?
Old Nov 6, 2003 | 01:55 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Coolant System Question (webdzynes)
Sounds like you need a new expansion tank.
Bill
Old Nov 6, 2003 | 09:22 AM
Oldvetter's Avatar
Oldvetter
Interesting question, IF you had a pressure leak then water should not get over 212 F, it should boil away, low coolant would cause overheating.
To Coolant System Question
