Check Engine Light: DIC Code P 0410
Old Nov 6, 2003 | 01:43 PM
c5rose's Avatar
c5rose
Default Check Engine Light: DIC Code P 0410
Monday my check engine light came on. I went through the codes and saw all "H"s after them with the exception of one.
It's under 10-PCM (Powertrain Control Module) and lists it as:
P 0410 H C
Anyone know what the AIR System is?
I recently had the battery changed and noticed slight leakage from it that ate away a very little portion of plastic underneath.
Old Nov 6, 2003 | 03:43 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Check Engine Light: DIC Code P 0410 (c5rose)
Your plastic vaccum lines under the battery tray need to be repaired,deteriated from acid.One of the lines goes to the air pump control valve :yesnod:
