Getting to 500 hp?
Old Nov 8, 2003 | 11:50 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Getting to 500 hp? (marco383)
Read my post again, slowly. I said heads/cam or a Magna or a centrifugal blower. $7k will buy you one of those options.
Actually you said heads/cam/exhaust/intake/mag OR ATI. But since I understand what you mean now, no need to argue semantics.
...for $6-7k you can have heads, cam, exhaust, and cold air intake, a magnacharger, or the aforementioned centrifugal blower.
BTW If you are looking for an ATI kit I recommend calling Andy @ A&A Corvette. I have not had experience with his kit personally BUT I do have experience with the stock ATI kit, and all of the problems I've had with the stock ATI kit his kit supposedly addresses. It also costs about the same and you'll get direct support from one of the leading supercharging guys in the industry.
Old Nov 8, 2003 | 12:01 PM
bruce1's Avatar
bruce1
Default Re: Getting to 500 hp? (2002corconv)
What did that system cost? Who dod you go to.
A local friend and old time drag racer repaired, fixed and troubleshot the system so I could finally get it going.
The first vendor I initially had went with, did not make me happy.
Bruce
Old Nov 8, 2003 | 02:48 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Getting to 500 hp? (bruce1)
Do those rails replace your stock fuel rails like the NXL system does?
Old Nov 8, 2003 | 02:54 PM
bruce1's Avatar
bruce1
Default Re: Getting to 500 hp? (ICULUKN-C5)
No, it is a second set of rails for the fuel to mix with the nitrous as it is injected into the cylinder.
[Modified by bruce1, 12:01 PM 11/8/2003]
Old Nov 8, 2003 | 06:19 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
Check my mods for 500+fwhp! :yesnod:
Old Nov 8, 2003 | 06:41 PM
2002corconv's Avatar
2002corconv
Default Re: Getting to 500 hp? (NIGHTMARE...2001)
This looks like the safe and good way to go. i was thinking of doing something similar (heads and cam).
I'm worried about super chargers and nitrous doing damage. My car only has 6000 mi on it.
Old Nov 8, 2003 | 06:50 PM
2002corconv
Nightmare:
if u go directly to Motor City Mold u can get a better price than WCC. Here's thier link. http://www.motorcitymold.com/
Old Nov 8, 2003 | 07:17 PM
NIGHTMARE...2001
Thanks...I'll check it out! Still working off the H/C install right now though!
Thanks for the tip...NIGHTMARE :thumbs:
Old Nov 8, 2003 | 08:42 PM
Targa C5's Avatar
Targa C5
Hi Steve,
Adding a Vortech supercharger to your Corvette will provide the added horsepower and torque you need, along with the highest degree of reliability possible.
Quality Features
* Vortech gear-driven supercharger with SQ Technology provides nearly silent operation with unmatched reliability
* Technologically advanced, high-efficiency impeller and housing design developed in Vortech's supercharger test cell
* Fuel system upgrades includes all components required for safe, dependable operation on today's engines
* Oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger, even under sustained boost conditions
* Inlet and discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps
* OEM-type cast aluminum mounting bracketry for "factory installed" appearance and rigidity
* Supercharger drive system includes all the necessary belts, pulleys and tensioner
* Integrated air-to-water, dual-pass charge cooler configuration allows for additional horsepower gains and features a sealed, maintenance-free design
* Compatible with factory OBD II engine management systems
* Vortech 3-year limited warranty
* Emissions legal in all 50 states
Fuel Management: High-Capacity Fuel Injectors and Hand-Held ECM Re-Programmer CARB EO #D-213-19
:steering:
Old Nov 8, 2003 | 09:04 PM
2002corconv
Default Re: Getting to 500 hp? (Keith@TigerShark)
Keith@TigerShark:
What should I expect to pay for the Vortech? How much should I pay to have a professional install? :cool:
Old Nov 8, 2003 | 09:12 PM
Targa C5's Avatar
Targa C5
Keith@TigerShark:
Hi,
Expect to pay around $6300 for the Vortech system. The systems are complete, allowing the experienced do-it-yourselfer an effortless installation. Hopefully some owners who had their system professionally installed will chime in with an approx. cost. Thanks for the interest. :cheers:
-Keith
Old Nov 8, 2003 | 09:17 PM
2002corconv
On a stock motor w/ Blackwing, headers, x pipe, and Corsa exhaust extras, what kind of power r we talking?
Old Nov 8, 2003 | 09:31 PM
  #33
LS1MASACRE's Avatar
LS1MASACRE
Just do the ATI supercharger with Andy @ A&A corvette. it will be around 500 rwhp :cool:
Old Nov 8, 2003 | 09:39 PM
  #34
Targa C5's Avatar
Targa C5
With the Blackwing, x pipe, and Corsa exhaust... you'll gain somewhere around 20 rwhp. The gain from the headers will differ depending on which length and design you go with.
A 2002 MN6 Coupe we worked on in-house gained a solid 20 rwhp from just Blackwing (and high-flow coupler), '02 Z06 main cats, and Corsa exhaust. Before these mods (completely stock), it put out 307.5 rwhp (SAE Corrected). After these mods, the same dyno showed 327.9 rwhp (SAE Corrected). That puts it at around 385 hp (net).
The Vortech system will add around 43% more horsepower to the stock LS1.
Old Nov 8, 2003 | 09:41 PM
  #35
2002corconv
Default Re: Getting to 500 hp? (LS1MASACRE)
The 500 hp sounds great. I would like to do that but I need a good tuner in Ontario canada (can't seen to find an experienced tuner here). Their a long way away for me.
Old Nov 9, 2003 | 02:25 AM
  #36
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Who is it from Corvette Garage that lives in Ontario? Matt? He might have some help or info for you. Go to the Canadian section of the forum under events. Most of the guys their are from out east. Under the "tool" bar you can do a search with your postal code too. :yesnod: I know racer44 met some guys on a road trip...I'll see if he has some info for you. As far as a Vortech installed, probably about $13,500cdn.
[Modified by lager99, 12:55 PM 11/9/2003]
Old Nov 9, 2003 | 09:16 AM
  #37
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
I know lots of guys here are trying to help you but, some are not reading your post properly or have no idea where Ontario is. :lol: Contact MattG mattglas@sympatico.ca he is a supporting Vendor on this forum, he lives in Ontario and he will put you in touch with one of the best tuners on this Foum ARE, which is Agostino Racing Engines, they are based in Ontario. Also, remeber all these prices the most these guys are quoting are in US $. I had a Vortech doen here in Alberta and it was around $13,500 Canadian out the door. :eek: Talk to Matt he will help you out with all your possible options. :cheers:
To Getting to 500 hp?
Old Nov 9, 2003 | 10:49 AM
  #38
2002corconv
Default Re: Getting to 500 hp? (Racer44)
I knew that they were quoting me in US. I will get in touch with Agostino Racing Engines on Mon. Thanks alot. How do u like your Vortech? How is the maintainance part of it? Do u go through alot of BS to keep it run'in right? Did u do any motor mods along with the supercharger? Any info would be appreciated. There is one place just across the boarder in N.F. N.Y, Kennedy Dyno Tune, they do the ATI for $8500 US out the door. They said I had to purchase the LS1_Edit software to.
:chevy
Old Nov 9, 2003 | 11:21 AM
  #39
Racer's Avatar
St. Jude Donor '11
:chevy
I like my Vortech. I had to go through a few belt problems and I sheared of the Vortech crank pins, but everything was taken car of by my tuner no charge with upgraded parts. It is personal decision of which S/C to go with, ATI's seem to be working really good now that they have worked out the bugs too. H/C packages are always a good choice. You really need to talk to MattG, he has a great stroker engine in his car. Maybe that would be another choice for you. As for my car, the car runs like a normal car with the S/C it can run as a daily driver, but when you get on the load pedal it wakes up big time. As with both S/C's you can get some great numbers with a basically stock LS1/LS6 motor. All I have is LT headers and a Blackwing. Right now is a good time to purchase parts for your car as our dollar is doing so well compared to when I did my S/C. :rolleyes:
Old Nov 9, 2003 | 11:34 AM
  #40
2002corconv
racer44:
Thanks alot, I just e-mailed MattG, and will wait for his reply. I checked out your site, AWESOME car, garage, and truck. How did u get Shania over .HA Ha.
Who did u go to for your engine dress up kit?
