Steering seems heavy!!
Old Nov 7, 2003 | 04:33 PM
nericreations's Avatar
nericreations
Default Steering seems heavy!!
Guys, my steeering seem very heavy, I checked the power steering fluid, and it was 1/2" low, so i added to cold/full, but it still feels heavy, I have a 2000, and I drove a 2001, it was like night and day, any suggestions?? :confused:
Old Nov 7, 2003 | 04:38 PM
Patches's Avatar
Patches
Default Re: Steering seems heavy!! (nroberts02)
Since you were low, have you noticed a leak? It there any fluid leaking that would lead you to the source of a leak? It's possible your PS pump is going or has gone south.
Check the area around the reservoir and pump and check the rack as well.
[Modified by Patches, 4:38 PM 11/7/2003]
Old Nov 7, 2003 | 09:21 PM
nericreations
Default Re: Steering seems heavy!! (Patches)
Thanks, I'll check that in the morning...anything else that could cause that?
Old Nov 8, 2003 | 03:43 PM
motoracer's Avatar
motoracer
Is it just reduced assist when not moving, or all the time?
If all the time, then check the pump, also can unplug the connector to rack and should get full assist all the time.
To Steering seems heavy!!
