After servicing my 2000 C5 6spd, it went into a delayed starting mode, That is, You must hold the ignition key in the start position for a few seconds before it will make a sound, then after the guages return to rest position it starts normally.
There are no codes in the DIC and have a new 78P battery, I've tried another key and held down the clutch switch on the firewall but nothing changes.
CAN ANYONE HELP ME LOCATE THE PROBLEM, I have the Y2K manuals.
After servicing my 2000 C5 6spd, it went into a delayed starting mode, That is, You must hold the ignition key in the start position for a few seconds before it will make a sound, .
Never heard of that :confused:
follow this link to get your codes https://www.corvetteforum.com/techti...D=26&TopicID=1
and then if you can't troubleshoot using your service manuals, post the codes here and I'm sure someone can figure it out. :cheers:
