Dead Pedal replacement????????????????????????????? ????????????
Old Nov 9, 2003 | 06:13 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Dead Pedal replacement????????????????????????????? ????????????
The deadpedal on my car I road race expired. Is there and after market one that is stonger. The car is impossible to drive with out it. I had to duct tape it yesterday when it broke out. Thanks :seeya
Old Nov 9, 2003 | 06:34 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Dead Pedal replacement????????????????????????????? ???????????? (John Shiels)
ttt, I broke mine a long time ago.. need replacements as well.. :crazy:
VR :cheers:
Old Nov 9, 2003 | 09:09 AM
MrEracer's Avatar
MrEracer
John, I road race my car also and I modified my dead pedal by shortening it 1-1/2". Much more comfortable for me. I have not broken this pedal, but if I did I would lay in some fiberglass on the back side of the pedal to add structural strength. What actually failed on the pedal, the bolt tabs or the main body of the pedal? If you are interested in a shortened, reinforced pedal, let me know and I will modify one for you...
Shirl
Old Nov 9, 2003 | 09:49 AM
ROD BROWN's Avatar
ROD BROWN
I installed an aluminum dead pedal cover over the plastic and I haven't had any problems as of yet.That might be the answer for the pedal breaking.Ireally don't know if you like them or not,but they seem to take care of the breaking,and unsightly appearance they acquire from hard use. :chevy :chevy :flag :chevy :chevy
Old Nov 9, 2003 | 10:39 AM
Targa C5's Avatar
Targa C5
Hi John,
We offer this new cast aluminum dead pedal that matches the factory brake and clutch pedals. It attaches over your existing dead pedal. From your description of the problem, it sounds like your entire dead pedal might be braking off. If that's the case, this may not be the solution for you, but I thought I'd mention it just in case. Good luck! :cheers:
With C5 logo
Without C5 logo
We also sell the new matching cast aluminum gas pedal.
With C5 logo
Without C5 logo
For more information, please click the following: http://tigersharkcorvette.com/Mercha...egory_Code=450
Old Nov 9, 2003 | 10:43 AM
John Shiels
Default Re: Dead Pedal replacement????????????????????????????? ???????????? (Keith@TigerShark)
Thanks guys for the help! The entire pedal broke off at the mounting points. I guess I can make an aluminum copy or or order 3 new ones as they can't cost much. Hieght and shape are fine for my legs. May be I could glass it to reinforce it. Thanks!
Old Nov 10, 2003 | 06:30 PM
John Shiels
22 bucks each so I ordered a spare.
To Dead Pedal replacement????????????????????????????? ????????????
