what code = 10PCM
Old Nov 9, 2003 | 11:02 PM
juser250's Avatar
juser250
Default what code = 10PCM
I checked my codes and a code came up as 10pcm. does any one know what code this is.
THANKS
Old Nov 9, 2003 | 11:12 PM
Q8Y's Avatar
Q8Y
Default Re: what code = 10PCM (juser250)
Maybe it's a problem with you PCM!
that what I got from my search, " 10 PCM Powertrain Control Module page 6-357 - 6-361 Domestic ", Hope that'll help.
wish you the best
Ahmed
Old Nov 9, 2003 | 11:37 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
"10-PCM" isn't a code, it's the module number.
It should have spun some real codes, starting with a "P", or said "10-PCM - NO CODES".
Old Nov 13, 2003 | 06:20 PM
ChasNMe's Avatar
ChasNMe
Default Re: what code = 10PCM (Matt Black)
i agree with matt
press and hold the options button (it does not matter if the car is on, you could do it while you drive)
hit the fuel button 4 times in quick succession
the DIC should go into auto mode showing the different modules and the # of codes each has
28 TCS Traction Control System ABS
?? RTD Real Time Damping
40 BCM Body Control Module
60 IPC Instrument Pane! Cluster
80 Radio
99 FIVAC Heater Vent-Air Conditioning
A0 LDCM Left Door Control Module
Al RDCM Right Door Control Module
AC SCM Seat Control Module
B0 RFA Remote Function Actuation
do not be alarmed if you do not list each module, my 99 hardtop only has 5 or 6 of them
it should say something like "10 PCM - No Codes" or "10 PCM - 2 Codes" (if you have 2 codes)
when it finishes cycling through, it will go to the top of the list, or you can stop it at any time by hitting one of the other buttons (1-fuel, 2-gauges, 3-trip, 4-options)
5-E/M boots you out, or it will do it automatically after about 2 minutes of no button pushing
use fuel and gauges to cycle between a modules codes
use trip and options to cycle between modules
at the end of the code will be an "H" (history, not current) or a "C" (current)
if you or anyone needs a list of the codes, i have them
jake
sorry so long winded
[Modified by ChasNMe, 12:13 AM 11/14/2003]
To what code = 10PCM
