Better Traction help
Old Nov 10, 2003 | 01:43 PM
angman5's Avatar
angman5
Default Better Traction help
Just back from a GM/ Ford shoot out in SC I have a 01 6M coupe with just bolt ons headers,stingers, no cats, vortech,new maf,air bridge, TB bypass,MSD wires, thats about it on the performannce side. 100% stock I ran a 13.2 @107 with mods 13.06 @112 with a lot of traction problems.
I saw Vettes with the same mods running 12.1 or 11.9 with drag radials can you recomend tires also I saw them running 17 inch on the back for the drag tires would the shorter tire bring my 3:42 gear down or will a shorter tire raise the gear ratio? I can never remmber that
Please help :sad: :cry :cry :cry :cry :nopity
Old Nov 10, 2003 | 02:26 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Better Traction help (angman5)
Go with the 275/40/17" it will change the ratio alittle. The BFG's are best for track but the Nitto's work well also. :thumbs: :cheers:
Old Nov 10, 2003 | 02:30 PM
LittleBoyBlu99
(Angman5) Welcome to the Forum. :seeya :party:
Old Nov 10, 2003 | 03:55 PM
yankeevetteconvert's Avatar
yankeevetteconvert
The 275/40/17 DR's will give the same perfofmance as a 3:55 gear.
Old Nov 11, 2003 | 11:48 AM
angman5's Avatar
angman5
Default Re: Better Traction help (LittleBoyBlu99)
Hey thanks for the tire info, But would the the smaller wheel change the ratio to higher that 3:42 or woold it drop the ratio to less than 3:42? :cheers:
Old Nov 11, 2003 | 11:53 AM
angman5's Avatar
angman5
Default Re: Better Traction help (yankeevetteconvert)
Hey thanks for the tire information, I don't want to sound stupid just want to make sure befor I spend the money the 17s will turn my 3:42 to about a 3:55 ratio.
That could be good news at the track :)
Old Nov 11, 2003 | 01:01 PM
yankeevetteconvert
As I stated above the smaller tire diameter will give you a 3:55 gear. Here is the math: 275/40/18 dia. = 26.7, 275/40/17 dia. = 25.7.
26.7/25.7 = 1.0389 1.0389 * 3.42 = 3.55
To Better Traction help
