427" Dyno numbers
Old Nov 10, 2003 | 02:40 PM
Speed Inc.'s Avatar
0Speed Inc.
Former Vendor
Default 427" Dyno numbers
This is in our 03 EBZ06
Our combo consists of:
Lunati 4.00" crank
Wiseco 4.125" pistons
Lunati 6.125" rods
Dry sleeved aluminum block
RGR stage 3 heads 2.05/1.60 valves
Custom Comp grind
Spec stage 3X clutch
Stainless Works 1 3/4" headers w/OR
Stock Z06 catback
Stock(unported)LS6 intake
Speed Inc ported throttle body
Blackwing
SLP bellows
Through full exhaust
503.9RWHP/492.9RWTQ
Open headers
520.2RWHP/492.4RWTQ
It runs on 93 octane, and I have been getting over 25MPG on the highway. Peak power is at only 6200, so it doesnt have to be revved sky-high.
We will be testing the Kooks 1 7/8" headers,as well as the LSX intake, and hopefully it will get us in the 530-540 range through the stock exhaust.
Tom http://www.ls1speed.com
1866-LS1speed
Old Nov 10, 2003 | 05:49 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: 427" Dyno numbers (Speed Inc.)
Good to see you posting on this forum. The 427 sounds like a beast :cheers:
Can't wait to see results from a set of Kooks and the FAST intake.
Old Nov 10, 2003 | 05:56 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Nice numbers, looking forward to the comparision of the SW headers versus the Kooks. :cheers:
Old Nov 10, 2003 | 05:58 PM
NJ99FRC's Avatar
NJ99FRC
From: If you can see the car behind you, your not going fast enough
through 3.42? or was it something taller?
Old Nov 10, 2003 | 06:01 PM
gstama's Avatar
gstama
Default Re: 427" Dyno numbers (Racer44)
Those are great numbers with the stock exhaust, did you use the stock cats.
Old Nov 10, 2003 | 06:05 PM
kumar75150's Avatar
kumar75150
Default Re: 427" Dyno numbers (gstama)
what kinda compression?
Old Nov 10, 2003 | 06:27 PM
Speed Inc.'s Avatar
0Speed Inc.
Former Vendor
-stock 3.42 Gears
-12.5:1 compression, but we run on 93 octane with 26* of timing with ZERO knock. We run tight quench, so we get away with some compression on 93 octane.
-I definatly feel the LSX intake and Kooks 1 7/8" will be worth considerable HP. The motor peaks at 6100 and stays over 500HP until 6800, seems like it needs more air.
I get over 25MPG on the highway too.
Old Nov 10, 2003 | 08:56 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
TOM:
That's awesome man and a big congrats!!!!! :cheers: :cheers: YOu know i will be watching closely how much the new intake will wake up these strokers and of course the other additions you add and test to pick up the power levels of the big cubed LSX motors!!!! :cheers: :cheers: :cool: :cool:
Old Nov 10, 2003 | 10:14 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: 427" Dyno numbers (MTI 427 Roadster)
Nice numbers! I guess my 418 isn't doing to bad at 518 RWHP and 505 RWFTs through 3.90 gears and 11.25 compression.I would be real interested in seeing the motor with 1 7/8" headers.
I saw that new intake at SEMA last week and it looks pretty clean. Looks like a power maker.......if they can get it on the market!
Old Nov 11, 2003 | 04:39 PM
DieL's Avatar
DieL
Default Re: 427" Dyno numbers (9D9LS1)
Wow thats crazy. Mines aint a hydraulic but my 388 put down 477 on its first pull with the dfi 7. With tuning im hoping for near 500 or so. Thats mighty impressive for an easily driveable car ! :cheers:
To 427" Dyno numbers
