DIY shocks or not?
Old Nov 10, 2003 | 05:09 PM
larrysb's Avatar
larrysb
Default DIY shocks or not?
I'm considering the 04 Z06 shocks for my Z51 vert.
Anyone do the install themselves or is this a job best done on the lift?
Old Nov 10, 2003 | 05:28 PM
MSIP's Avatar
MSIP
Default Re: DIY shocks or not? (larrysb)
http://www.c5forum.com/diy/shocks.php
Looks like a moderate knuckle-buster, but still a bolt-on. I'm gonna do mine in a couple of weeks on jack stands... :chevy
Old Nov 10, 2003 | 05:32 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Not a bad job at all ! 2 hours If you take your time. I've done two. :smash:
Don't forget the large Zip Ties!! :yesnod:
Old Nov 10, 2003 | 06:14 PM
Kenny94945's Avatar
Kenny94945
If you are handy it is not too bad, can do from a chair and the wheel off. No need to lift entirely. Do you know what I mean?
Budget 2 to 4 hours which includes break-time.
Here two tricks. Collapse the shock with a string zip tie to get in in & out of its mounting position. If the front shock doesn't line up, lift the lower arm with a jack and it will aid positioning.
P.S. Make sure all your bilstein parts are correct before you disassemble! Also check your suspension mount bolts with a torque wrench while you are in there.
Old Nov 11, 2003 | 07:02 PM
Default Re: DIY shocks or not? (MSIP)
Thanks for the tips. Great article.
Old Nov 11, 2003 | 08:15 PM
7LitreC5's Avatar
7LitreC5
It's not a bad job at all. I didn't know about the zip tie trick so it took a little bit of doing to get the shocks compressed to get in and out. It took me about 2 hours to put the shocks on and swap out the front sway bar.
Old Nov 12, 2003 | 01:19 PM
rbz06's Avatar
rbz06
Did mine a couple of weeks ago. Its a must do mod you wont be sorry. the zip tie thing is a little tricky but other then that its not bad at all.
:flag
To DIY shocks or not?
