PCM TACH WIRE
Old Nov 10, 2003 | 08:19 PM
vettemaster1's Avatar
vettemaster1
Default PCM TACH WIRE
WILL THE SIGNAL FROM PIN 10 [TACH] ? RUN AN AFTERMARKET TACH? IS THE SIGNAL SIMILAR TO NEG POST ON SINGLE COIL SETUP? :confused:
Old Nov 11, 2003 | 12:03 PM
C5Tuner's Avatar
C5Tuner
Default Re: PCM TACH WIRE (vettemaster1)
Yes, it will run an aftermarket tach (most that I know of anyway). Autometer actually has a small tech article on their website about it. I just installed a 5" sport comp in my own car and it works wonderfully!
Mike
Old Nov 11, 2003 | 12:42 PM
vettemaster1
Default Re: PCM TACH WIRE (C5Tuner)
thanks mike. just for grins where did you make the conection? keith ;)
To PCM TACH WIRE
