PCV mod does not work
Old Nov 10, 2003 | 09:20 PM
FRC sexi blk's Avatar
FRC sexi blk
Default PCV mod does not work
I have had the PCV mod (Campbell catch can version) installed for a year. Today I take off my manifold and find lots of oil all over the head ports and inside the manifold.
I have a 2000FRC with 30k miles.
I noticed something interesting about the PCV mod. It only filters out the oil from the left (drivers) side head. If you notice, your TB has two vacuum lines from the PCV system. The main black one on the bottom, and there is a silver line at the right top.
So I pull the hose that connects this right top vacuum line and it has a lot of oil in it. It connects to the right head. IF you also look at the head, it has TWO pcv venting lines. One that connects to the TB, and the other that connects to the left head. How strange???
So this is my question to all you tech people. I re did my PCV system. I connected my left head PCV vent to the bottom PCV line with the catch can using a "Y" connector, then connected the left head to the other o port of the "Y" connector. Capped off the top vacuum port on the TB, and capped off the extra PCV vent on the right head.
Will that work? My car consumes too much oil, now I know its not an oil ring problem, its the cheap butt PCV system!
Old Nov 10, 2003 | 10:21 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: PCV mod does not work (cute301guy)
It didnt work on my car either... so I went out and completely changed everything... :smash:
VR :cheers:
Old Nov 10, 2003 | 10:23 PM
FRC sexi blk
Default Re: PCV mod does not work (vetterdstr)
what did you change? I'd like to hear more about your design please.
Old Nov 10, 2003 | 10:27 PM
vetterdstr's Avatar
vetterdstr
LS6 blower motor, Heads, cam, Longtube headers, Supercharger, LS6 intake, One way PCV check valve... I think you get the Idea... and guess what?? No more oil in the PCV system!! :eek: :blueangel:
VR :cheers:
Old Nov 10, 2003 | 10:33 PM
FRC sexi blk
grr. that didn't help any :U
Old Nov 10, 2003 | 10:34 PM
vetterdstr's Avatar
vetterdstr
:lol: yeah, it is an expensive way to go (although rewarding) to stop the oil consumption... :hat
VR :cheers:
Old Nov 10, 2003 | 10:35 PM
WRK CAR's Avatar
WRK CAR
[QUOTE] It didnt work on my car either. [QUOTE] :iagree: So can somebody post somthing that will work. :cheers:
[Modified by WRK CAR, 9:42 PM 11/10/2003]
Old Nov 11, 2003 | 07:28 AM
YO-EL's Avatar
YO-EL
Default Re: PCV mod does not work (WRK CAR)
I actually took my oil mod off.
I didn't like how my car ran with it. Felt sluggish.
Old Nov 11, 2003 | 07:51 AM
ArKay99's Avatar
ArKay99
I saw this and thought it might be helpful. http://www.ls1howto.com/index.php?article=18 Good luck. :flag
BTW, if you need the coolant hoses and stuff also, you can get the stuff here cheap. http://forums.corvetteforum.com/zerothread?id=684497
[Modified by ArKay99, 7:55 AM 11/11/2003]
Old Nov 11, 2003 | 12:54 PM
FRC sexi blk
Default Re: PCV mod does not work (ArKay99)
interesting. have you updated to the ls6 valley on your car?
Old Nov 11, 2003 | 03:22 PM
ArKay99's Avatar
ArKay99
Not yet. I'm waiting for the new FAST manifold to be released. I am planning on doing that when I swap the new manifold in.
To PCV mod does not work
