B & M Ripper or Hurst?
Old Nov 11, 2003 | 03:46 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default B & M Ripper or Hurst?
Thinking about putting in a short throw shifter... Which one would you guys prefer the most?
Old Nov 11, 2003 | 04:43 PM
FactoryRaceCar
Default Re: B & M Ripper or Hurst? (Knowme)
ttt
Old Nov 11, 2003 | 04:47 PM
adame780's Avatar
adame780
I have the B&M and I am very happy with it.
Old Nov 11, 2003 | 04:49 PM
jim-b-sr's Avatar
jim-b-sr
check out the Breathless Performance Products shifter, it seems to be pretty good and is most likely the one I'm going with.
Old Nov 11, 2003 | 04:52 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I recommend doing a search on this forum and the Z06 forum. I recently went through the same exact process. You will find numerous Polls and opinions on this topic.
There are many options out there, but the B&M and Hurst tend to be at the top of the list. I decided to go with the Hurst Billet Plus Shifter. Excellent quality! I'm really happy with mine. No noise.
Short shifters sometimes tend to produce a little more noise over the stock shifter. You can eliminate noise with a good ****, i.e., MGW or MoMo billet steel, because the added weight absorbs the vibration (Do not use the stock ****!).
There are also a few easy tricks you can apply, such as using a 1.5" and 2" rubber PVC cap with a 5/8" hold drilled in the center that you slide down the shaft of the shifter that also elminates vibration and noise. I also recommend getting the Ken King or MoMo short shifter leather boot.
Good luck with your choice. Either one is much better than stock and you will really like the way if shifts - really exact and positive feel - the way a Corvette should shift.
Mike
[Modified by AlohaC5, 12:20 PM 11/11/2003]
Old Nov 11, 2003 | 04:56 PM
88sk's Avatar
88sk
Default Re: B & M Ripper or Hurst? (AlohaC5)
its a no brainer because of adjustability& price ,HURST,the most used shifter here,I love mine.
Old Nov 11, 2003 | 04:59 PM
gmblack3's Avatar
gmblack3
Default Re: B & M Ripper or Hurst? (adame780)
:iagree:
I tired the breathless for a few hours in many of the different angles available and could not get comfortable with it. It also seems to be a little taller then the ripper.
The ripper went back in.
Old Nov 11, 2003 | 05:27 PM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Would recommend the Hurst because of adjustability. Both the Hurst and Ripper are short on throws, precise and quiet. Hmm, being quiet is not guaranteed as it depends alot on the installation and **** used. I have had both in my cars and like both shifters, but would go with the Hurst imo.
Nate
Old Nov 11, 2003 | 05:33 PM
FactoryRaceCar
Default Re: B & M Ripper or Hurst? (gmblack3)
OK Guys thank you all for all the help. I have made up my mind I am going with the Ripper. Where can I find Ken King Boot? Searched everywhere no luck :smash:
Old Nov 11, 2003 | 05:35 PM
ACCURATE's Avatar
ACCURATE
Ripper gets my vote .. :D = have not tried the hurst .. but I love the ripper :)
Old Nov 11, 2003 | 05:39 PM
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
I have the shortened Ken King boots in black, in stock. Will make a package deal for the boot and shifter if interested.
Nate
Old Nov 11, 2003 | 05:42 PM
FactoryRaceCar
Default Re: B & M Ripper or Hurst? (Nate@CorvetteGarage)
Nate, I also bought a BlackWing Intake from you. I liked your service. Email me with the price. Thanks
Old Nov 11, 2003 | 05:49 PM
poolfanatic's Avatar
poolfanatic
You may also want to look at the Kirban. I have one in my 03 Vette and love it. Much more positive feel than the Ripper (in my opinion).
I'm in Houston so if you'd like to meet somewhere this weekend (MTI maybe), I'd be more than happy to let you row the gears a little and see what you think.
Old Nov 11, 2003 | 06:03 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Hurst... nuf said :thumbs:
Old Nov 11, 2003 | 09:16 PM
bbster's Avatar
bbster
I have the Ripper in the Coupe and the hurst in the Z Love UM :thumbs:
Old Nov 11, 2003 | 10:17 PM
PeteyPete's Avatar
PeteyPete
Default Re: B & M Ripper or Hurst? (bbster)
I love my hurst :thumbs:
Old Nov 12, 2003 | 01:12 AM
Z06forGM's Avatar
Z06forGM
I put a Ripper in my Z06, and the shifting is great! The only drawback is the new shifter makes alot of noise over the stock shifter.
I checked back with West Coast Corvettes, and was told the design is different than stock and thats why the noise is there. It sounds more like a rattle when you stomp on the gas. As far as I am concerned, I don't like the noise and am thinking of removing it.
Check them out BEFORE you buy so you know what you are getting into.
Old Nov 12, 2003 | 07:29 AM
Cajun99's Avatar
Cajun99
Love my Ripper...nuff said :D :hurray:
Mine has no rattles at all. :yesnod: :seeya
Old Nov 12, 2003 | 11:40 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: B & M Ripper or Hurst? (Cajun75)
Ken's stuff is also availble directly from him. http://www.vetteessentials.com/
To B & M Ripper or Hurst?
