Fuel Filter Location
Old Nov 13, 2003 | 04:42 PM
geoc's Avatar
geoc
Default Fuel Filter Location
Someone posted here before that the fuel filter location on C5's were under neath the car in the front on the drivers side directly under the rest pedal for your left foot.
I changed mine today on my 98 and it wasn't in that location. It was in the back of the car on the driver's side just above the muffler pipe and exhaust pipe connections. :smash:
Old Nov 13, 2003 | 05:00 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Fuel Filter Location (geoc)
Yup! :yesnod: My '99 has it there too.
Old Nov 13, 2003 | 05:22 PM
USA Muscle's Avatar
USA Muscle
Default Re: Fuel Filter Location (LoneStarFRC)
The guy that posted that is was in the front had his car turned around and was just confused !! :crazy: :p: :lol:
Old Nov 13, 2003 | 10:13 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Re: Fuel Filter Location (USA Muscle)
:D :lol: :D
Old Nov 13, 2003 | 10:19 PM
Shortimer's Avatar
Shortimer
How hard is it to replace the gas filter? It was a pretty tough job on my C4. :nonod: I have no trouble getting the car in the air. If the filter is easy to get at I might want to change it out as the car has hit 12K. :chevy
Oh, is it a Delco part, something the Chevy dealer is likely to have in stock? :)
[Modified by Shortimer, 3:21 AM 11/14/2003]
Old Nov 13, 2003 | 10:27 PM
LoneStarFRC
Default Re: Fuel Filter Location (Shortimer)
Not too bad really. If you don't already have them, then pick up a set of the quick connect tools for disconnecting the fuel lines. You can get a set very reasonably priced. The plastic ones work just fine. Oh yeah. Don't forget to relieve the fuel pressure at the fitting under the driver's side coil cover first. After that it's pretty straight forward. With only 12K on your car, I wouldn't think you would be a fuel filter candidate quite yet. These things have a fairly large capacity. I'm still running my factory filter and I'm at 82K. Of course I also put 3 1/2 oz of Red Line SI-1 in each and every tankfull (and a full bottle at oil filter change time). HTH
Robert :)
Old Nov 13, 2003 | 10:40 PM
Shortimer's Avatar
Shortimer
Thanks for the info. You're probably right about the low mileage. At the first sign of rough idle or anything similar I'll be taking a close look at the filter. I will toss in some Chevron injector cleaner next long trip I make. :chevy
To Fuel Filter Location
