Gear ratio for 99 M6
Old Nov 14, 2003 | 10:15 AM
Heretic's Avatar
Heretic
Default Gear ratio for 99 M6
It it worth it to upgrade to 3.73? Seems like you can get a brand new rear diff for 2k with factory 3.73s. It it worth it over the 3.42s?
I worked out the ratios vs a m12 3.42 combo and first is pretty close, and the OD ratios don't get cut down too much.
Old Nov 14, 2003 | 10:59 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: Gear ratio for 99 M6 (Heretic)
The answer to your question IMHO depends on what other mods are done to your car.
If you are pretty much stock I would suggest you go for the rebuild of the rear with the bigger 4:10 gears to make the most difference in your quickness.
On the other hand if you are highly modified you may need to stay with the 3:42s.
I am somewhere in the middle of all that and opted for a new 3:73 setup.
Hope this helps!
