98 w/ high oils pressure?
Old Nov 17, 2003 | 08:24 AM
Blacked-out's Avatar
Blacked-out
Default 98 w/ high oils pressure?
I just had the oil changed and my 98. At idle the pressure is 35psi, running cold at 35k rpm pressure is at 65psi, then down to 46psi. Someone suggested pcv valve, should I try OEM or something different. I also have excessive oil consumption---any suggestions?
:banghead:
