Underdrive pulley/ Belt part numbers??????????
Old Nov 17, 2003 | 10:58 AM
Bad Bob's Avatar
Bad Bob
Default Underdrive pulley/ Belt part numbers??????????
Well the title says it all, can anybody tell me the part numbers for the new belts I will need since going with the ASP underdrive pulley? Any help is appreciated and thank you in advance. Bob
Old Nov 17, 2003 | 11:23 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: Underdrive pulley/ Belt part numbers?????????? (Bad Bob)
Bob,
I will check later today and post if noone responds by then. I have the belt jackets out now as I am headed to the parts store to get an extra set.
Chuck
Old Nov 17, 2003 | 11:42 AM
Bad Bob's Avatar
Bad Bob
Default Re: Underdrive pulley/ Belt part numbers?????????? (AnteVenom)
ty very much
Old Nov 17, 2003 | 01:47 PM
Bad Bob's Avatar
Bad Bob
ttt
Old Nov 17, 2003 | 02:56 PM
AnteVenom's Avatar
AnteVenom
Bob,
The info I have from the jackets I have at home is as follows:
Manufacturer = GATES
1st belt # - K060775 - 21mm X 1980 mm
2nd belt# - K040410 - 14mm X 1060 mm
Hope this helps!
:cheers:
To Underdrive pulley/ Belt part numbers??????????
