Problem with FOB memory
Old Nov 17, 2003 | 11:38 AM
2000TicketMachine's Avatar
2000TicketMachine
Default Problem with FOB memory
My FOB's suddenly stopped working, so I re-synchronized them and it solved the problem.....for a day. It seems the the re-sync only lasts a day or so and I have to redo it. Anybody have an idea here? Thanks!
:cheers:
Old Nov 18, 2003 | 09:14 AM
ProDesign's Avatar
ProDesign
Default Re: Problem with FOB memory (2000TicketMachine)
Sounds like possilby the battery contacts are losing contact with the battery. When the keyfob is in your pocket it bounces around and the case gets squeezed open every so slightly causing the battery to loose contact. Check for bent or missing battery contacts in the key fob. Note the contacts are very fragile.
Old Nov 18, 2003 | 01:24 PM
Terry34's Avatar
Terry34
It sounds like your fob is going bad. Does the other fob have a problem? If not and a new fob battery doesn't help I would bet the fob has gone bad. Not an uncommon problem.
To Problem with FOB memory
