swapping converter
Old Nov 19, 2003 | 06:50 PM
tohigh4you's Avatar
tohigh4you
Default swapping converter
ok, ive got a chance to pickup a used yank 3500 stall ....ive got 3.15 gears.....heres my questions.... is there any programming needed with computer or will stall swap not effect computer.....second, when swapping to higher stall ive always heard tranny cooler necessary......or does stock cooler work.....just trying to plan for problems a little ahead..... also, car is complete stocker.......and will converters interchange with all year C5's....ive got 2001....car im getting from in 98 i think......
thanks,
john
Old Nov 19, 2003 | 08:11 PM
Killrwheels's Avatar
Killrwheels
Default Re: swapping converter (tohigh4you)
based on all my contacts with Mike at Yank, this converter is too high for your gear set. Should be looking under 3000 or upgrade to 3.42/3.73's.
I bought a SY-3500 new, and offering it for sale as I think it may stall to high for 3.42's with minor mods.
http://www.converter.cc/converter_choice_guide.htm
I would suggest contacting Mike at Yank with your specific requests/questions before purchasing a unit that may make you unhappy. Go straight to the source (smart idea huh ??)
[Modified by Killrwheels, 7:40 AM 11/20/2003]
Old Nov 19, 2003 | 10:07 PM
tohigh4you's Avatar
tohigh4you
thats not what i wanted to hear....im going to add vararam soon...but i am only trying to get the car into 12's....so i wont see too many mods after converter/airbox.....i dont want to perform a mod that doesnt make sense....ok, all the smart/experienced C5 guys lets hear your input....
thanks,
john
:chevy
Old Nov 20, 2003 | 12:07 AM
Mitch C's Avatar
Mitch C
thanks,
john
When you install a high stall converter your shift points will not be as firm as before. Unless you have your shift points firmed up by reprograming your computer. Which Yank 3500 do you have (SY3500 or ST3500) the SY3500 has a low STR and will feel rather loose with your 3.15 gears. The ST3500 has a high 2.5 STR and will not feel as loose as the SY3500. Installing a tranny cooler is a VERY good idea when you install a high stall converter it is cheap insurance. If this converter came out of a C5 it will work in your car, 97-04 there all the same. I would recommend you also install at least 3.42 gears with your T/C, not only will you get better performance they will also improve your cars driveability with a high stall converter by making it feel tighter. :cheers:
[Modified by Mitch C, 11:12 PM 11/19/2003]
Old Nov 20, 2003 | 09:07 AM
tohigh4you's Avatar
tohigh4you
its the SY3500 model.....ok, now im having second thoughts because Ive already heard gears are around $500 for a set.....add that to cost of converter....install price...tuning....ill be at 1600-1800 before i know it.....guess ill have to start a new thread and see best mods for spending less than $1000......
thanks everyone for your help.....
john :nopity
Old Nov 21, 2003 | 12:24 AM
gojo's Avatar
gojo
Save up. IMO there is no better start to mods than the SY3500 and 3.42's, for street and some strip.
Old Nov 21, 2003 | 04:56 AM
Mitch C's Avatar
Mitch C
Default Re: swapping converter (jfpilla)
:iagree:
Save up and install your gears and T/C together, if you install them separately you will have to pay the same labor charge twice. :yesnod:
To swapping converter
