c5 suspension question
Old Nov 19, 2003 | 10:47 PM
brad6285's Avatar
brad6285
Default c5 suspension question
i have an 03 50th anniversary vert mn6 and recently bought the gm part
direct z06 sway bar upgrade. gm says that the rear sway bar is the same on the z51 suspension. i dont know what suspension i have is it the z51 or the f55 (magnetic selective ride contol). thanx for your response
Old Nov 19, 2003 | 10:51 PM
mnotx's Avatar
mnotx
Default Re: c5 suspension question (brad6285)
If you have the 50th Anniversary edition, then you have the Magnetic Selective Ride Control. It is part of the package.
Old Nov 19, 2003 | 10:52 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
if you have f55, you'll have a rotary switch in front of the center storage with performance, sport, something... on it
you can see your rpo codes on the inside of the glove compartment. look for Z51 or F55 on the list of codes.
Old Nov 19, 2003 | 11:01 PM
joemoia's Avatar
joemoia
There should be a label on the inside of your glove compartment door that lists all the options installed on the car. IIRC on the 50th AE, MSRC was standard equipment and Z51 was not an option for that model.
Old Nov 19, 2003 | 11:21 PM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Re: c5 suspension question (joemoia)
Put the new bars on!!! You'll love it!
THe bars you have currently are not Z51... the are part of the base FE1 suspension package... the F55 shocks are an upgrade to the base suspension.
:thumbs:
To c5 suspension question
