Lowering Problem (Front) long
Old Nov 21, 2003 | 10:17 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Default Lowering Problem (Front) long
I removed both the bolts that rest against the A arms and go up through the leaf completely. Now when I make a complete U turn (either side) the car makes weird noise like clunk clunk clunk. It is so LOUD and so bad that it feels like my wheels are going to come right off and if they did not I would DEFINATELY break something for sure :smash:
Is this noise due to torsion bar rubbing directly against the bottom A arm?
I would also like to mention that my front tire size is 275/40/17. I had the tires on there before lowering the car but they never rubbed.
Secondly, I took the car for a complete 4 wheel alignment. The guy was having all sorts of problems for the front alignment. The car still pulls to the left heavily. According to him, the toe and camber is aligned but there is noway to fix caster unless I have different camber bolts.
any help would be greatly appreciated :cheers:
Old Nov 22, 2003 | 01:48 AM
JakeL's Avatar
JakeL
Default Re: Lowering Problem (Front) long (Knowme)
Having the leaf spring rub directly on the a-arm sounds like a really bad idea to me. I'd try cutting down your bolts to just one rubber pad left, and reinstall them.
Not sure why it would make for a clunking noise, but anything is possible. The springs in your car are fiberglass/compositve leaf springs, not torsion bars.
Caster can be adjusted - a couple ways on a C5. Since the lower control arm has two mounts to the body, pushing the rear one further out will move the BJ forward, and give you a bit more caster (and vice versa for the other direction, and for the front etc)
Also, behind the upper control arms are spacers. Sometimes there are none, one, or two. Adding and subtracting those (don't go more than two, running zero is fine) will alter your caster also.
I'd find a different alignment guy, and put the bolts back in your springs. I've got about half of the stock bushing left, and can't imagine the car being much lower than it is, and still even drivable on public roads.
I hope that helps some,
Cheers!
-Jake
Old Nov 22, 2003 | 02:29 AM
torched you's Avatar
torched you
well after i took my front bolts out my car it made the same sound after i cut and put my bolts back in its been fine
Old Nov 22, 2003 | 05:37 PM
FactoryRaceCar
Default Re: Lowering Problem (torched you)
Thanks so much guys. This all really helped me. Now I have another problem, I have lost both the bolts :( I will try local chevy dealership to get them and install them back.
Thanks anyways for all the help again :cheers:
Old Nov 22, 2003 | 10:45 PM
corvette dave's Avatar
corvette dave
Default Re: Lowering Problem (Knowme)
The last time I checked you can't buy just the bolts. You have to buy the front spring.
See if someone here will sell you their old ones.
Dave
To Lowering Problem (Front) long
