I have been having idle issues ever since installing my Stealth cam. Finally got it to calm down a whole lot by replacing the MAP sensor behind the intake. It idles a lot smoother now...much more like a 220/220 cam should and doesn't surge at all now.
Re: Idle is much improved now after sensor change (flynbludream)
Can someone please explain what the MAP sensor has to do with idle ? I used to think if you have problems with an idle either you computer tune it or largen the throttle body hole . :confused:
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Re: Idle is much improved now after sensor change (low98vette)
________________________________________ ________________________ I would like to know too. I am having idle problems. Thanks Tate
I'd also like to know
Mine doesn't idle smoothly either.....Did the idle relearn, had the injectors cleaned, new plugs, wires, air filter......ya-da, ya-da, ya-da. Sometimes when I'm tring to drive slowly (just a little above idle) my car will go into a "bucking" mode. It's not that I'm going to slow in too high a gear (luging) I have 4:10's and it still happens. 1998 with 84,000 miles
Re: Idle is much improved now after sensor change (V8_Club)
[QUOTE]________________________________________ ________________________________________ ________________________________________ ________
Hi vette#one , what is the idle relearn ?
This will explain the why.....and how http://www.c5forum.com/diy/idlerelearn.php
