Rear axle nut size??
Old Nov 23, 2003 | 02:51 AM
SpinMonster's Avatar
SpinMonster
Default Rear axle nut size??
Anyone know the size nut that holds the drive axle to the rear hubs? 32mm?
Old Nov 23, 2003 | 02:58 AM
SpinMonster
Default Re: Rear axle nut size?? (SpinMonster)
Sorry just saw the other post....34mm
Old Nov 23, 2003 | 03:56 AM
z0sense's Avatar
z0sense
Just curious why you had to take yours out?
My output shaft broke inside of mine so I am welding a slide hammer to it to get the broken piece out....
BTW,
I started the other post.
Old Nov 23, 2003 | 11:31 AM
SpinMonster
Default Re: Rear axle nut size?? (z0sense)
I had a mishap that caused the need to change the rear gears/transmission. I can't get one of the drive shafts in so I want to remove it from the car to clean up the splines.
You are getting a HD shaft now I imagine? Good luck.
To Rear axle nut size??
