whining from the rear?
Old Nov 23, 2003 | 04:11 PM
98tranz's Avatar
98tranz
Default whining from the rear?
Ok guys i tried using the search, but couldn't find a sound answer. On my 00' c5 i have been hearing a whining noise from the rear. There is NO NOISE at idle, and NO NOISE when cruising with foot OFF the gas. It is when i am cruising, and press the gas, i hear a high pitched whining from the rear. I am thinking that it may be a fuel pump, but i don't know The car has 27,000mi. If it IS the fuel pump, do you guys replace it with the GM one, or an aftermarket one? Thanks guys, all help is appreciated
Old Nov 23, 2003 | 06:22 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: whining from the rear? (98tranz)
I don't think it's the fuel pump. You would hear it all the time-idle, cruise, etc. Sounds more like a ring/pinion noise. Kinda hard to tell without being in the car. With low miles, seems like that would be unlikely. Have a shop listen to it. SCOTT
Old Nov 23, 2003 | 06:38 PM
99C5ragtop's Avatar
99C5ragtop
Take your kid out of the trunk.... :lolg: :lolg: :lolg:
Sorry I couldn't resist.
:cheers:
Old Nov 23, 2003 | 07:05 PM
Sack Rat TT's Avatar
Sack Rat TT
98tranz-On my 99FRC I had the same thing happen from about 35-40mph upward. Occured during easy accellerate more than decellerate. I had two months to go on warranty and my dealer replaced the complete unit. I had about 27,000 miles showing as well. Does not sound like a fuel pump. Good Luck
:cheers:
To whining from the rear?
