Low washer fluid
Old Nov 23, 2003 | 09:22 PM
redbaron's Avatar
redbaron
Cruising
Default Low washer fluid
Help! A couple of weeks ago I got a DIC message that the my 2000 FRC windshield washer fluid was low. I checked the reservoir and sure enough, the fluid was down. Filled it up, and since then, everytime I drive it, I get the same message on the DIC. It has to be cleared by the reset button. I tried clearing all codes on the DIC but the message returns like an unemployed college student. What do you think? Bad sensor? If so, is relacement difficult?
Old Nov 23, 2003 | 10:16 PM
Miaugi's Avatar
Miaugi
Default Re: Low washer fluid (redbaron)
When I had my overflow tank off I noticed that the sensor needed a slight adjustment. The sensor consisits of a magnetic switch that is ativated by a magnet in the floating arm. On my car the arm did not move "freely", I removed the arm by pushing out the pin and then sanding off a little material on the arm and then re-assembling the whole unit. It works fine now. I would think that your "arm" also does not move freely and needs to be sanded to allow free movement.
Old Nov 24, 2003 | 06:33 AM
IMQUIK's Avatar
IMQUIK
Since I never drive mine in tha rain, I ditched the washer fluid & put Vodka in it.Ran a line to just under the dash. :lol: :lol: :lol: :lol: :jester
Old Nov 24, 2003 | 06:56 AM
V8_Club's Avatar
V8_Club
Default Re: Low washer fluid (IMQUIK)
:lolg: :lolg: :lolg: :thumbs: good method to solve that pesky problem .
To Low washer fluid
