Bent rim fix?
Old Nov 24, 2003 | 05:43 PM
awschucks's Avatar
awschucks
Default Bent rim fix?
I have a 2002 Z06 with stock rims that has about a 3/16 bend on the inside of the rim. I'm not sure if this is an aluminum or mag. rim. Can it be straghtened. Has any one done this?
Old Nov 24, 2003 | 05:51 PM
HummelS's Avatar
HummelS
Default Re: Bent rim fix? (awschucks)
I bought a set that turned out to have a slightly bent rim on one of them. Local wheel shop straightened it out for $100.
Old Nov 24, 2003 | 05:57 PM
allanlaw's Avatar
allanlaw
Default Re: Bent rim fix? (thevettenet CA)
Steve, do you have the name?
Old Nov 24, 2003 | 06:16 PM
HummelS's Avatar
HummelS
Default Re: Bent rim fix? (allanlaw)
Hi, Allan - no, my tire shop sent it out for repair. In LA, you might check out http://www.wheel-repairs.com in Sta. Ana - I talked with them at Cruise for a Cure & they seemed to be a pretty good outfit.
[Modified by thevettenet CA, 3:16 PM 11/24/2003]
Old Nov 24, 2003 | 06:31 PM
quiettrader's Avatar
quiettrader
These folks do SUPER work. Here is the link:
http://www.wheelcollision.com/wccspecs.html
Old Nov 24, 2003 | 06:47 PM
allanlaw's Avatar
allanlaw
Thanks, Steve. I sent them an email. I have two "wagon wheels" from the '98 that are slightly out-of-round - no visible damage, and the wheels can be balanced but not perfectly.
How's tricks? Haven't seen you in a while. As you can tell by the sig, I wound up buying an '01 (from a Porsche dealer in Riverside). The other deal we had talked about didn't work out because of the leasing company.
Old Nov 24, 2003 | 07:02 PM
Bill Vett's Avatar
Bill Vett
Default Re: Bent rim fix? (quiettrader)
These guys are great!!! I had the wheels re-done on my 93 ...1 dent..1 curb rash.. all 4 stripped re-done $500.'s and a two day turnaround. The wheels looked new!!!
To Bent rim fix?
