Brake Pads Crumbled
Old Nov 24, 2003 | 11:25 PM
bigDvette's Avatar
bigDvette
Default Brake Pads Crumbled
Went racing this weekend using PFC-Z pads. My rotors were agressivelly grooved out and the pad of course matches them. The edges of the pad are crumbled with sections of the pad near the edges missing. It's like someone hit it with a hammer in sections and it crumbled.
The pads have a significant amount of taper to them and it seems to be opposite on the leading vs. trailing edge. The outer pad was tapered at the leading edge and the inner was tapered towards teh trailing edge. Would that be because the caliber is not aligned properly?
Also, anyone have experience with Wilwood Js. I went through these PFC-z pads in 2 events where I got about 3 or 4 20 minute sessions on the TMS inner track. Seems like they should have lasted a bit longer, although I am very rough on the brakes.
Old Nov 25, 2003 | 12:26 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Brake Pads Crumbled (bigDvette)
:eek: :eek: :nonod: :nonod: :steering: :smash: :withstupid: :troll
Old Nov 25, 2003 | 01:57 PM
bigDvette's Avatar
bigDvette
Default Re: Brake Pads Crumbled (LittleBoyBlu99)
ttt
Old Nov 25, 2003 | 03:29 PM
VetteDrmr's Avatar
VetteDrmr
Well, I'd try the autocross/road racing forum as far as the brake pad crumbling goes. Had you bedded them in before-hand?
As far as the LE/TE tapering goes, is that on one side only? If so, then I'd guess you've got either a caliper pin or piston that's sticking and causing the caliper assembly to "fowl" slightly. Otherwise the taper should be symmetric.
And, as always, AIR, AIR, AIR! to the brakes. All I do is autocross, so I don't have a heating problem, but if I ever start tracking, two things I'm going to do:
1. Engine Oil cooler
2. Brake ducts to the fronts
HTH, and have a good one,
Mike
Old Nov 25, 2003 | 07:11 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Those pads are not made for heavy use. That is what will happen unless you go real easy on the brakes. The rotors grooved because the metal got HOT. You need better pads, Wilwood or PFC 01's and a few other available. You need ducting also and tie rod end protection. If you got it hot the rubber boots are probably burned up near the rotor. You need to then replace the enitre control arm. :eek: LGM will really have spindle ducts soon. Stainless steel pistons from DRM along with the DRM ducts.
Old Nov 25, 2003 | 07:31 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Brake Pads Crumbled (John Shiels)
John is right on. After losing one tie rod end boot I cover them and I also put some wrap around the lower ball joint boots. The pad tapering was probably due to caliper flex. First time I went to the track with my 97 I tapered the pads so bad the dealer warrantied all of them front and back. You probably had a low pedal after a few sessions. The only pads I haven't tapered are Hawk Blues. They are a very high torque pad and all you have to do is breathe your foot across the brake to get a lot of stopping power but do they do eat the rotors.
Bill
Old Nov 25, 2003 | 11:33 PM
John Shiels
Default Re: Brake Pads Crumbled (C5inNY)
You can't find anything on the car cheaper to do than cover the ball joints except wash it :lol: I ran a whole set of PFC 01's on a rotor and the rotor had NO wear due to cooling. Part way into the second pad set it split big time in two places on one rotor so watch them.
Old Nov 26, 2003 | 12:49 AM
Bob25thTA's Avatar
Bob25thTA
Would like some information on wrapping tie rod ends and better cooling ducts. What are you guys using?
Old Nov 26, 2003 | 05:29 PM
John Shiels
Default Re: Brake Pads Crumbled (Bob25thTA)
DRM ducts and the LGM spindle ducts. I just take some heat shield tubing and wrap and safety wire it. Cheap & easy! I'll try to find some pictures or take some tomorrow as I prep the car for VIR
Old Nov 27, 2003 | 11:24 AM
Jim 47's Avatar
Jim 47
John is right BigD. You need air to the brakes and better pads. The PF01's and the Carbotech XP9's are very good for the track and quite similar in performance. Also shielding as many things as possible from the heat of the brakes will be beneficial to surronding parts.
Jim
Old Dec 8, 2003 | 09:43 AM
bigDvette's Avatar
bigDvette
Default Re: Brake Pads Crumbled (Jim 47)
Thanks for all the replies guys.
So what does the tie rod end boot look like? I ask because I lost I have this rubber boot with a slit in the end that someone said came off my car yet I can't find where it would have come off.
I want to upgrade to wilwood brakes all together, but I can't find a good tire combo other than hoosiers. John, what do you run.
I'm looking this winter to get John at CCW to change my wheel sizes. I run 335/30/17 in the rear and 215/35/17 in the front. Kumhos of course. I need 18s to run wilwood package acording to Lou.
I'm going to redo all this stuff this winter. I've got 1 more event and I replaced the PFC-zs already with well PFC z again.
I just switched the entire suspension to 2004 z06 suspension over the weekend and brakes / ducting / heat shielding will come right after my next event. When it is 50 out the brakes stay pretty cools, so hopefully that will help.
Anyway I need a tire combo to switch out the brakes.
Donald
Old Dec 8, 2003 | 10:36 AM
John Shiels
I am running the GY GSCS in GS sizes 275/315 x 17 going to a bigger tire next year on my next set of rims. I need two sets of rims. I'll look to see if I have a tie rod picture wrapped or take one this week. The rims I will order from CCW will let me run scrubs, Hoosiers, and real slicks..
Old Dec 8, 2003 | 11:16 AM
bigDvette's Avatar
bigDvette
Thanks John so you run stock brakes with Wilwood pads?
John has just about talked me in to scrubs as well on 18s. If you run real slicks will you run GY slicks?
To Brake Pads Crumbled
