Are the 97 to 99 MAF the same??????
Old Nov 26, 2003 | 11:50 AM
tabbruzz's Avatar
tabbruzz
Default Re: Are the 97 to 99 MAF the same?????? (kewlbrz)
I called the dealer and the part numbers are the same....
Old Nov 26, 2003 | 11:56 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
:iagree: and I read a post a couple of months ago where it was decided that the older ones were still the best--
Old Nov 26, 2003 | 11:57 AM
H82BFST's Avatar
H82BFST
Default Re: Are the 97 to 99 MAF the same?????? (Godspeed)
That's only the upper limit in the PCM. The MAFs are the same.
Anyone ever check out an LT1 MAF? ;)
Old Nov 26, 2003 | 12:47 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Are the 97 to 99 MAF the same?????? (H82BFST)
I find it interesting that LPE uses the older MAF on their Turbo cars (or at least I was told by one of their customers they used too).
Old Nov 26, 2003 | 01:05 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
I believe it just related to the PCM. The 97/98 MAF PCM table maxes out at 11250HZ at 428.52gm/s. The 99/00 MAF PCM table does go up to 12000HZ however it flatlines 428.52gm/s from 11250HZ to 12000HZ. My guess would be the physical MAF is the same, but the PCM calibration is slightly different. If you aren't maxing our your MAF I would not worry about it.
[Modified by Godspeed, 12:06 PM 11/26/2003]
Old Nov 26, 2003 | 02:05 PM
tabbruzz's Avatar
tabbruzz
Default Re: Are the 97 to 99 MAF the same?????? (BADBLACK99)
I have a stock de-screened '99 MAF off my car. Let me know if you need it. :)
BADBLACK99, I sent you an IM as I would appreciate the MAF.....Thanks Tony
