Failed Emissions Test
Old Nov 26, 2003 | 12:46 PM
Wt99C5's Avatar
Wt99C5
Default Failed Emissions Test
Just ran my 99Â’ thru the Emissions Test and failed. :bb
The dude at the emissions station asked if I recently had a dead battery. Well, a few weeks back I installed a new Red Top and have been on the road for work since. He suggested I call the dealer for help. Any one else have this problem and know how many miles before the PCM would show a state of READY.?
[Modified by Wt99C5, 5:47 PM 11/26/2003]
Old Nov 26, 2003 | 01:21 PM
ArKay99's Avatar
ArKay99
Default Re: Failed Emissions Test (Wt99C5)
I believe it's how many miles, but how many starts. It might be in the service manuals, but I'm at work now. I'll check them when I get home later and if someone hasn't answered you and I find it I'll post you back. :thumbs:
Old Nov 26, 2003 | 01:36 PM
TLewis4095's Avatar
TLewis4095
If you put a hundred miles on it the PCM usually has relearned again....but the idle re-learn is quicker. Do a search in the archives for instructions. :cheers:
Old Nov 26, 2003 | 01:44 PM
Son93SL2's Avatar
Son93SL2
I have always heard 2 tanks of gas :leaving:
Old Nov 26, 2003 | 02:19 PM
Wt99C5's Avatar
Wt99C5
ArKay, I have the manuals, but can’t find what I’m looking for, no surprise. But you might be on to something. I was able to find a Warm Ups w/o Emission Faults counter. The counter runs from 0-255 and is reset to 0 if power is lost. The problem is, it doesn’t say how many starts are required to connect to the State’s Emission System, or even if this is the problem. I’ll keep looking.
Tlewis, I haven’t tried an idle relearn since installing the new battery. The emissions guy said the car’s got a bad miss. I told him it was the new spark plugs. Guess he couldn’t tell it was the cam.
Son93SL2, Hope it’s not 2 tanks a gas. 2 tanks would last me till next year’s emissions test. :lol:
Also, I only have the same old :bs codes.
1064
2606
1096………
Old Nov 26, 2003 | 02:39 PM
TLewis4095's Avatar
TLewis4095
Possible bad O2 sensor may cause a rich condition as well....especially if you have a miss. Did you look at your old plugs that came out? Were they a lite grey-tan? All is well if they were....but covered in black soot shows rich. Also, if new plugs were just installed check wires to see that one did not get streched & broke when removeing them....center conductor damage not visible from the outside. Or a bad plug from the start....all could cause failed emmisions.
Good luck! Quick way to see whats wrong is hook it up to an engine scanner and see. :thumbs:
Old Nov 26, 2003 | 08:20 PM
texasredc8's Avatar
texasredc8
Default Re: Failed Emissions Test (TLewis4095)
I think you can only have 2 Not-Readys or the car will fail the OBDII test. You can always opt for the dyno or sniffer test........ at least in Texas you can.
Takes 50 ignition cycles to bring the PCM up to Ready state.
Old Nov 26, 2003 | 08:43 PM
Monster231's Avatar
Monster231
Default Re: Failed Emissions Test (TexasRedZ06)
:iagree:
Old Nov 26, 2003 | 08:57 PM
Wt99C5's Avatar
Wt99C5
Ouch 50 ignition cycles...! I sure picked a bad time to replace the battery. Guess I'll shut her off at every stop light. Thanks for the info.
Old Nov 26, 2003 | 11:06 PM
Gary2KC5's Avatar
Gary2KC5
50 ignition cycles will clear a code or change it from a "C" current to "H" history status. That may not be the issue though. The idle re-learn usually takes about 30 miles or 30 minutes of driving.
Pull your codes and see what you've got cooking.
I'm assuming your test is strictly with the OBDII and not sniffing the exhaust.
Old Nov 27, 2003 | 09:05 AM
Wt99C5's Avatar
Wt99C5
Default Re: Failed Emissions Test (Gary2KC5)
My best guess is I have about 10 ignition cycles completed since the battery swap. I checked the codes yesterday; they were all the normal crap codes such as 1064, 2606, and 1096. The interesting thing is they are already History codes. Makes me wonder if displayed codes are stored in a non-volatile area of the PCM and counters are cleared\ reset once power is lost. So far the only thing I can find in the shop manual is this counter ….Warm Ups w/o Emission Faults ….
Yeah, I don’t believe the sniffer test is an option here anymore. Truth is, I don’t think it would pass anyway. After installing all my mods, she’s running Burn your eye’s rich. . I hope to check things out with EFILive later this morning. What I really need to do is drop it off at nevrenuf’s house and have him work some of his magic.
Old Nov 27, 2003 | 09:26 AM
bowtiebandit's Avatar
bowtiebandit
Hope this helps................................... .........
Inspection/Maintenance Status Reset Procedures
System Status For Satisfying the Federal Inspection/Maintenance (I/M) Regulations
The scan tool System Info menu includes the System Status selection.
Several states require that the vehicle pass on-board (OBD ll system) tests for the major diagnostics prior to having a vehicle I/M emission inspection. Some areas may require that the vehicle pass the OBD II system tests and the I/M emission inspection in order to renew license plates.
Using a scan tool, the technician can observe the System Status (Complete or Not Complete) in order to verify that the vehicle meets the criteria which complies with the local area requirements. Using the System Status display, monitor any of the following systems or a combination of the systems (depending on vehicle make and model) for I/M Readiness:
Catalyst
Heated Oxygen Sensor (HO2S)
Heated Oxygen Sensor (HO2S) Heater
Exhaust Gas Recirculation (EGR), if so equipped
Evaporative Emission (EVAP)
Secondary Air Injection System (AIR), if so equipped
Important
The System Status display indicates only if the PCM has completed the required tests (DTCs). The System Status display does not necessarily mean that the test has passed. If a failure indication is present for a DTC associated with one of the above systems, that test has failed. Diagnosis and repair are necessary in order to meet the I/M requirement. Verify that the vehicle passes all of the diagnostic tests associated with the displayed System Status prior to returning the vehicle to the customer.
Following a DTC Info Clear, battery disconnect, or a control module replacement, all of the System Status information will be set to Not Complete.
Refer to the diagnostic support information associated with each DTC in order to obtain the Conditions for Running the DTC. The vehicle operating conditions that the system must meet in order for a DTC to run are the Conditions for Running the DTC.
The System Status table shows the DTCs that must run in order for the System Status to indicate a system test has been Completed.
System Status System Status
DTCs Used to Set System Status
Catalyst
P0420, P0430
HO2S
P0133, P0153, P1133, P1134, P1153, and P1154
HO2S Heater
P0135, P0141, P0155, and P0161
EGR System
(If so equipped)
P0401
EVAP System
P0440, P0442, P0446, P1441, or the Service Bay Test
AIR System
(If so equipped)
P0410
Scan Tool Tests
The scan tool for some systems depending upon the vehicle make and model include the Service Bay Tests. Use the Service Bay Tests in order to test certain systems and reset the System Status to Complete. The EVAP Service Bay Test is included for this vehicle. Refer to the Service Bay Tests for important preliminary instructions.
Old Nov 27, 2003 | 09:45 PM
Wt99C5's Avatar
Wt99C5
Default Re: Failed Emissions Test (bowtiebandit)
:yesnod: Thanks ! :thumbs:
To Failed Emissions Test
