FE 45 Disconnect
Old Nov 26, 2003 | 08:03 PM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
Default FE 45 Disconnect
If I disconnect this will it throw codes? I am thinking of doing this so I can lower it DOWN. Any thoughts would be Great :smash:
Old Nov 26, 2003 | 08:20 PM
blue98coupe's Avatar
blue98coupe
Default Re: FE 45 Disconnect (TmillerC5)
if you disconect the shocks you will get a code that will not let you drive over 85mph ,I had mine lowered with the f45 still connected ,if you are going to go with different shocks you can have the f45 turned off in the computer or do like I did you use 3 watt 15 ohm resistors .You put the resistor inline between the two wires after you disconnect the plug from the shock .Good luck :cheers:
