help!!! strange noise after gear install
Old Nov 26, 2003 | 11:41 PM
night feeder's Avatar
night feeder
Default help!!! strange noise after gear install
i just had 3.90s put on my car and they told me to drive the car normally for 500 miles and then change the gear oil. everything was fine for the 500 miles and i changed the gear oil today. for some reason now theres a really really loud whine it seems like coming from the gears. it's very very loud when i'm barely on the throttle but when i floor it or go to half throttle the whine goes down in volume almost to wear you cant hear it :confused: is this normal after a gear oil change or should i be really worried about this. if anyone knows whats going on then your help is much appreciated :cheers:
oh yea... when the noise is really really loud the shifter is vibrating somewhat
Old Nov 27, 2003 | 12:00 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: help!!! strange noise after gear install (night feeder)
everything was completely fine until the gear oil change?
What type of fluid did you use?
Old Nov 27, 2003 | 12:08 AM
night feeder
Default Re: help!!! strange noise after gear install (Mike Mercury)
i can't remember the name of it, it was ams oil i think... started with an a, ECS gave it to me to use so it must have been the right oil. and yes it made absolutely no noise until after the oil change
Old Nov 27, 2003 | 12:30 AM
white shark's Avatar
white shark
call the person who installe it the gears for u and they shoyld be able to tell u whats going on. good luck :seeya
Old Nov 27, 2003 | 01:50 AM
night feeder
Default Re: help!!! strange noise after gear install (white shark)
does anyone know what could be wrong :confused: i don't understand why this would happen after changing the gear oil.. has anyone had this problem? any ideas of what it could be?
Old Nov 27, 2003 | 07:34 AM
martin97c5's Avatar
martin97c5
weird , i dont see how oil could make a noise?? maybe u disnt put enought in?? Mine made some noise whne i first got it, then it went away, ha they never told me to change th eoil after 500 miles?? mine is still the same oil from when the car got the gear change.
martin
Old Nov 27, 2003 | 07:42 AM
BT-01-vette's Avatar
BT-01-vette
Did ECS do your gears? If so call them and let them know what's going on, I'm sure they would get right on it. Good luck.
Old Nov 27, 2003 | 09:54 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Did you put the additive in also, I'm pretty sure that along with the gear oil theres also another additive.
Old Nov 27, 2003 | 10:36 AM
dpd's Avatar
dpd
first,make sure you put in the right amount of fluid.also,did you put in the limited slip additive?
Old Nov 27, 2003 | 10:38 AM
tabbruzz's Avatar
tabbruzz
Default Re: help!!! strange noise after gear install (runamuk)
ECS will take care of it so call them.......It's like an art setting up these gears and they can become noisey if the adjustment is a bit off, even over time. Chris is a good guy and should correct the issue.....
Old Nov 27, 2003 | 10:40 AM
night feeder
Default Re: help!!! strange noise after gear install (tabbruzz)
i'm going to call chris at ECS but i doubt he's at work today because of thanksgiving. they didn't tell me about the limited slip additive :confused:
Old Nov 27, 2003 | 10:46 AM
dpd's Avatar
dpd
the limited slip additive keps the clutches in the rear from chattering/sticking.what fluid did you put back in?some fluids already have the additive in it,but most don't.if you leave the additive out,the rear will make all kinds of noise,especially when turning.
Old Nov 27, 2003 | 10:48 AM
tabbruzz's Avatar
tabbruzz
Some of the aftermarket gear oil has the additive in it. The additive would really help for turning more. If you are hearing a whine just while driving straight then Chris will most likely need to reset the gears. Or you can try getting the gm gear fluid and additive and try that first.... Either way Chris will tell you best....
Old Nov 27, 2003 | 11:45 AM
Mike Mercury
it's time to start looking elsewhere (other than the fluid).
When you changed the fluid... did you jack-up the car... do it on a lift... ramps?
Did something get slightly displaced; maybe a half-shaft that wasn't fully seated in the first place?
Old Nov 27, 2003 | 11:57 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Something is wrong... The Oil chris gives to customers Amsoil... you shouldnt need the additive with it. Did you put in the entire two bottles???
Either way give Chris a call at the shop tomorrow... he'll be there all day. If the gearset were set wrong they would have started singing before this. I never heard of a rear singing after a fluid change. Unless there isnt enough fluid in it. :confused:
Either way we'll get it straightend out....
Mike
:cheers:
To help!!! strange noise after gear install
