Eagle Run Flats
Old Nov 27, 2003 | 11:55 AM
VetteJet's Avatar
VetteJet
From: Ashburn, VA Looks Like I picked the wrong week to stop drinking
Default Eagle Run Flats
Purchased a 2000 coupe last winter and having my first experience with Goodyear Eagle "run flats". I've heard that the run flats are going to be a little rougher and I can feel a slight vibration, nothing major, but more than I would expect. Shop can't find anything worng, but didn't take them off either. Friends tell me that its all in my head.... Any experience out there?
Old Nov 27, 2003 | 12:06 PM
msuc5vette's Avatar
msuc5vette
Default Re: Eagle Run Flats (VetteJet)
They probably just need to be balanced.
If a tire isn't worn perfectly even accross the tread width it will vibrate.
Does it feel like it is the front or the rear?
Old Nov 27, 2003 | 12:15 PM
VetteJet's Avatar
VetteJet
Default Re: Eagle Run Flats (msuc5vette)
yea, I feel it more in the front end. New tires, maybe a bad install. I'll take it back for a re-balance and tell them to stop giving me that "they will run a little rougher" line...thanks.
Old Nov 27, 2003 | 12:23 PM
msuc5vette's Avatar
msuc5vette
IMHO the rougher only applies to big bumps, make sure they use wheel weights on the inside of the wheel!
Old Nov 27, 2003 | 12:24 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
(VetteJet) Welcome to the forum!
:seeya :cheers: Your car may need a front and rear alinement. :thumbs:
Old Nov 27, 2003 | 12:34 PM
VetteJet's Avatar
VetteJet
Default Re: Eagle Run Flats (LittleBoyBlu99)
Thanks, glad to be here. Happy Thanksgiving.
Old Nov 27, 2003 | 12:37 PM
carpe dm's Avatar
carpe dm
Welcome to the Forum! It could be all of the above: in your head, balance problem, or alignment. It could also be a bad tire! Not all of them are perfect; I had a Michelin that could never be balanced properly and had a bad vibration over 60 mph. I changed tires and the car is now a pleasure to drive!! :yesnod: :)
To Eagle Run Flats
