Difference between 98 - 99 owner's manual?
Nov 28, 2003 | 10:17 AM
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
I just purchased my first Vette. (Happy me!) It is a 98 coupe and came with
a 99 owner's manual. Is there a difference - should I track down the 98 one? :steering: Thanks. I'm enjoying this forum.
[Modified by 98qcksilvermom, 8:42 AM 11/29/2003]
Nov 28, 2003 | 10:19 AM
Re: Difference between 98 - 99 owner's manual? (98qcksilvermom)
Yes - there is a difference. You can order an OEM owner manual for your 1998 C5 here:
http://helminc.com/helm/homepage.asp?r=
[Modified by 1999 White C5 Coupe, 9:21 AM 11/28/2003]
Nov 28, 2003 | 10:24 AM
Cruise-In V Veteran
Re: Difference between 98 - 99 owner's manual? (1999 White C5 Coupe)
Thanks, Can you tell me briefly what that difference is?
Nov 28, 2003 | 10:26 AM
Cruise-In VI Veteran
Yes...The 99 has heads up option...the 98 does not.
There is a GM web site where you can download your owners manual in PDF for free but I lost the link.........
Maybe some one could chime in and post it to this thread.
Kevin
Nov 28, 2003 | 10:29 AM
Cruise-In V Veteran
Re: Difference between 98 - 99 owner's manual? (69)
So if I don't have "Heads Up display" it doesn't make a difference?
Nov 28, 2003 | 10:40 AM
Nov 28, 2003 | 10:42 AM
Cruise-In V Veteran
Link does not work....
Nov 28, 2003 | 10:44 AM
Cruise-In V Veteran
Typed the link into address bar - worked!! Thanks
Nov 28, 2003 | 11:19 AM
:thumbs:
Nov 28, 2003 | 09:40 PM
St. Jude Donor '06-13,'16-'17, '19
Just for additional info, there are also differences in the electrical schematics in the service manuals too. Don't even attempt to use the 98 schematics on a 99 car.
Tom
Nov 28, 2003 | 11:07 PM
There is a lot of similarity but there are also enough differences that you would be better off with the correct manual. Another difference is in the fuel system. You'll see two fuel lines on the '98 and one on the '99. :cheers:
Nov 29, 2003 | 09:44 AM
Cruise-In V Veteran
Re: Difference between 98 - 99 owner's manual? (MMarquez)
Thanks again you guys - have one lined up on Ebay! :steering:
